I was just looking online at the two HF 5 hp compressors. I read a review of the 62299, 3 cylinder model and the reviewer said it was really a single stage. I looked at the manual that claims it is a 2 stage but there is an air filter on each cylinder head BINGO!! In a 2 stage compressor the second stage cylinder(s) get their air from the first stage cylinder(s) not the outside air. I even looked at a true 2 stage, 3 cylinder, separate head pump, and only two cylinders had air filters. Also you can see the common output manifold for all three cylinders. The real 2 cylinder, 2 stage, 93274 goes to 165. The three cylinder only goes to 150psi. Even for HF this is a new BS or incompetence level. Both compressors have the same specs and price but they pump the same 60 gal tank to 150 and 165 respectively. Make sure you buy the right one if you are thinking about one of theirs.
