I just put together the HF blast cabinet last night. The fit and finish is actually quite decent, it does NOT have 500 screws and rivets like the mail order import kind that ships in a flat box, that you have to put each panel together.
The hopper and cabinet was its own piece, all was needed was put them together, and the legs.
There were a couple HF stock numbers for the cabinet, I insisted they gave me the higher stock # which must be the latest version. (also had the mid shelf to add some stablity). I heard some recommendation on here to caulk the joints, mine already was caulked all around and I see no need to do so. Maybe I will around the outside seams of the hopper just in case.
I didn't hook up the gun it came with, I am going to order the skat gun from TPtools.
I bought a mover's dolly at HF for cheap, stole the casters and made a 3/4" plywood cart for the cabinet, this raised 4.5" so I cut the legs by that same amount. The legs are anchored down and won't flex around now.
If you know any tips to use this thing just let me know. I am have a shopvac I was going to throw away due to weak motor, maybe I will use on this for a while.
