HF Brake Bleeder as fluid extractor
johninct
I have a job that would be made much easier if I could use a fluid extractor instead of taking everything apart to get the oil out. I was wondering, if I could use my HF Brake Bleeder as a fluid extractor for 85, 90-140 wt. gear oil? I have used it on Gas many times and it worked fine but did not know if gear oil would be too much? I need to use a small tube to fit, but it is only about 2 quarts.
engineer2
Chicago burbs
I assume you mean their pneumatic bleeder? If so, it would probably work, but it would be slow going especially if the oil is cold, Can you get the end of the hose to where it needs to go?
65ranchero
Danville, VT left NJ forever
J
johninct
I have a suction gun but its hose is too wide and short to get to the bottom. I could rig up adaptors but when I pull the suction gun, I could not get that much oil out every stroke. That is why I want to use the brake bleeder, I could use let it run until I had a quart.
Jeepster04
Ive used a vacuum brake bleeder to **** out diff oil and it took FOREVER.
AJHD
I've never used it for a heavy weight oil like that, but yes, I used to have one in the shop and used it constantly to evacuate reservoirs (brake fluid, power steering, even coolant). You can even put it down a dipstick tube sometimes.
rlitman
Long Island
It needs to be warm first. Just like engine oil.
While the numbers are way higher, gear oil isn't all that much thicker than motor oil. They work off different charts.
turtleman321
Harrisburg, PA
i beg to differ.
75w140 is wayyyyyyyyyyyyyyyyyyyyyy thicker than 15w40 when its 35 degrees out
rlitman
Long Island
i beg to differ.
You can feel the 15% difference? Un huh.
toyotadriver
I have and have used the Holt bleeder below for gear oil and it works fine. The warmer the fluid the better. If you have a small heater like a Mr. Heater Buddy heater or a torpedo heater, you can jack the vehicle up and then aim the heater at the differential and let it run for awhile.
J
johninct
Just an update, I bought a MightyVav air power fluid extractor. I needed to use the smallest tubing I could buy so I could get it into the bottom. I created a vacuum, turned my air off and let it **** all night. It worked fine!!! The limiting factor was how far could I get the tubing in.
