I have two in my shop. One goes out all the time with the slightest bump. .
Does anyone that has one of these know if the battery is easily replaceable? Not immediately obvious to me just looking at the pictures. The Harbor Freight light is appealing to me as you can just unscrew the end and replace the battery.
Nice. Thanks Jason. I'll be picking up a third one. After I replaced the cells mine run for well over 4-5 hours at a time.
The only time I've had a "malfunction", was when I inadvertently loosened the base while positioning it, losing battery contact.
I went back to HF and bought two more lights and that's when I discovered a bonus feature.
With two lights, stick the magnetic ends together and pretend you have a Darth Maul Light Saber and chase the dogs through the house.
The rubber o-ring on my battery cap has split. They seem to be very fragile. It is a very fine o-ring. Any ideas on where to get another o-ring this size? Also can someone post a link for the high end Samsung batteries?
I’m about 7 months in of daily use after buying 2 of these lights and the charging ports are completely whipped out of both. USB plugs have no business in an industrial environment. The lights both work fine including the one I got wet and had to dry it out to get it working and the other I burned with torch slag. I bought a two bank automatic charger off Amazon to charge batteries and prefer this setup anyway as I can charge when I please and not have to monitor charging through the light. All in all these work great for my uses.
I use a Nightcore D2:
https://www.amazon.com/dp/B00KW2ZDJO/?tag=atomicindus08-20
Can you send a link to the type of charger you bought?
