HF electric hoist trolley
Steve from Socal
Hutchinson Ks.
I needed a little hoist for my surface grinder to load and unload work. The grinder is in a room with a metal roof. I attached a section of Unistrut to a purlin for the hoist to travel on. The hoist will be used to pick up heavy for a person <50Lbs but, not more than about 200Lbs.
Harbor Freight has several 120 VAC electric hoists, I got the smallest one rated at 440 Lbs. I got the smallest one to limit the lift capacity, if I need to load a heavier piece I will use some other means. The hoist I got is a nice compact little device, it came with straps to mount on something like a single section Unistrut. I wanted a moving hoist so the strap mounts won't work. The other issue I had was, the hoist comes with a 5' long cord for the control pendant. My hoist will be 14' up, a trip to Home Depot for 10' of 12-4 Soow and, a bit of time fixed that.
To make the hoist mobile it needed some Unistrut trolley's, there were two options at least on ebay there were only two. I could have bought two of the light duty single axle trolleys for 20 bucks a piece or so or, a single dual axle trolley for 30 bucks. I cut the trolley in half with my sawsall and had just about exactly what the smaller trolleys were for 25% less money. I used some material that I had laying around for the bases of the trolleys. The material was a locking bar for a cabinet that was damaged and discarded. The nice thing about the material is it has stiffening flanges bent into it on both sides. Now we are on a roll!
The last thing to do is get power to it, traveling hoists have a few ways to supply them with power. I am going to use the simplest, a cord suspended by cable next to the hoist. This is where I am today, I will edit and include pictures when I finish.
Steve
moonpool145
South Florida
I have 4 mounted in my garage. Two right next to a wall for picking up heavier bits like a portable table saw, for wall hanging and 2 mounted over work areas. I used 1 1/4" pipe for mine and it works awesome. Never hang anything very heavy but tested
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
moonpool145
South Florida
Almost forgot.... I have everything braced heavily in the rafters and through bolted. As for moving the hoist, I just put a dab of grease on top of the pipe and it moves very well even with a decent load on it.
Bobf
Poway, CA
I bought one of those probably over 10 yrs ago to lift stuff up to the roof of stores I had to install antennas on the roof. I have a couple actual link chain hoists but have been using the little 440/880 lb electric with the supplied ****** block to lift car engines/trannys in and out without any problems. The early Olds with hydro's are well over 700#'s but it seems to work without strain. I probably wouldn't recommend getting under it but it does work great.
Oregon rock crusher
West of Salem
Yes I agree these little hoist work pretty well for light lifting jobs. I use one to get electric motors and other heavy items into the attic for storage. Once you lengthen the cord and add weight to the hook they are pretty helpful. Mine is on door track with a modified wheel truck which keeps it tight to the track. I do need to get one of those coiled extension cords that play out along the wire without tangling. Here is a not so great pic looking up at the hoist. Ed.
kbs2244
Just a note to those that may want to use pipe.
NPT are tapered and never mean to be used in any kind of weight supporting role.
Hanging any kind of weight from a vertical male into female joint is a for sure “ maybe”
Steve from Socal
Hutchinson Ks.
I can e-mail my pictures to myself no connectivity with my phone.
Here is the hoist, i need another person to put it up.
Steve
Steve from Socal
Hutchinson Ks.
A friend came over and lifted me up to hang the hoist. Gotta get the cable to support the power cord tomorrow.
Steve
