So, last weekend, I did a preemptive strike on the dreaded Ford Triton/Modular two-piece spark plug change. I am happy to report that I was 10-for-10; no broken plugs! Not that there weren't some tense moments...I only have 50,000 miles on these plugs, but after all the horror stories I've read about them, I decided to replace them early. Truck was running great before the change and still is.
In the process, I had a moment of panic as the little machine screw that holds the collar on the harbor freight locking extension fell out into my spark plug hole. Luckily the plug was still in place and some swearing and a magnet was able to retrieve the screw before it fell into the engine or was lost forever.
After breathing a sigh of relief, I put a dab of threadlocker on the threads and tightened the screw back up. As I checked my other extensions, I found them all very loose. So, here's a tip for everybody who has these extensions: Inspect them before use, add a little threadlocker, and tighten up the screw. Don't be like me.
Here are the extensions I'm talking about:
http://www.harborfreight.com/hand-tools/sockets-ratchets/4-pc-12-in-drive-quick-release-extension-bar-set-67977.html
and
http://www.harborfreight.com/hand-tools/sockets-ratchets/4-pc-38-in-drive-quick-release-extension-bar-set-67976.html
I like these extensions, they just have this flaw that needs to be looked after. I took at a look at my Gearwrench locking extensions and noticed that they put a red band over where this screw would be. I had always though that was "for looks", but now I understand that they probably use the same type of retaining screw and are doing me a favor with that red band...
Chris
and
Chris
