HF Mini air ratchets any good?
johninct
I was in HF and saw the mini air ratchets. They were so small. Are they any good? Does anyone (Tool truck) else make ones that small? Thanks!
efb16acrx
2ndGearRubber
Pittsburgh
Mine was a bit stiff in the reverse/forward selector. It broke-in just fine, pretty happy with it overall, and I'm not an air-ratchet guy either.
404
Mass
They often are not strong enough to break bolts loose. However in a tight space like the 10MM head bolts on a timing belt cover they can be a wonderful time saver and frustration reducer. They can be good under the dash on smaller fasteners. Am glad I got mine. I took the paddle off to make it fit smaller spaces.
Regards,
404
stikman56
They work, but they are not powerful. I assume you're talking about the ones with the green cover? The covers are garbage and rip and kind of actually smear away until they just fall off.
AndrewV
Fl
I have a little bluepoint one.(finally got it back from my SO rep)
Mainly use it for dash work. And works great.
Can see doing it with a hf one, just as good.
