onthefence777
- Joined
- Feb 19, 2012
- Messages
- 404
So a while back I bought a HF 7x10 Mini Lathe on craigslist. It was in pretty rough shape, missing all change gears, ways were a bit rusty, power feed did not work, and the carriage and crossfeed slide had a TON of play in them. I went through it, got all the surface rust off of the way and got it in pretty decent overall shape. Read up a lot about it, and got all the gibs adjusted very nicely, performance was drastically improved.
But I still was getting quite a bit of runout on the chuck. The chuck is by no means precision, but with the jaws in the correct orientation, it doesn't seem like it was coming from the chuck. Since the runout became apparent when I was putting pressure into the work, and it was accompanied by a rough bearing noise from the headstock, I figured it was the headstock bearings.
Since I was tearing down the headstock anyways, I decided to upgrade the regular roller bearings for the angular contact bearings at littlemachineshop.com. Since the angular contact bearings are slightly wider than the roller bearings, a spacer had to be turned down to make up for the difference. I bought a spare spacer, and a neighbor that also has a HF mini-lathe let me turn it down on his lathe, and use his press to remove/install the bearings in the headstock.
So I got it all back together, and voila! Chuck run-out was basically entirely gone. It seemed to run WAY smoother than before, and so after the brief "break in" recommended (spinning at slow speeds for a couple minutes, increase speed in increments for a few minutes) I tested it out by doing a facing operation with spectacular results! I then began to do a turning operation, not a big cut at all but not a finish cut either. Well after less than 15 minutes of operation the motor started groaning and turned very slowly and then wouldn't turn.
Upon removal of the motor, I discovered that the motor brushes were pretty well worn out. I have new motor brushes to install. I am hoping that that is the only problem with the motor.
But this is where my question comes in - I am wondering if I didn't turn down the spacer that puts preload on the headstock bearings enough. When I turn the chuck with very slight effort, it turns very smoothly with no resistance, but instantly stops if I stop turning it - I.E. it does have drag on it. I wouldn't call it "tight", but it definitely doesn't free spin. Is it possible there is too much pre-load on the headstock? Should it spin freely? Is it possible that this placed too much load on the motor, and consequently wore out the brushes? Or was this just a coincedence?
Any advice would be greatly appreciated. I am going to start swapping in the new brushes tonight, and see if hopefully the motor is ok.
