HF mityvac hand pump clone. - got brake fluid in it.
petee_c
KW area, Ontario CANADA
Got one of these for brake fluid changes etc.
I think I got some brake fluid in the pump when doing a recent brake flush on my motorcycle. Still works (both the motorcycle brakes and the vacuum pump)
Anything I could use to flush it out? or just hope that it keeps working... I use it fairly infrequently, maybe twice per year....
WWheeler
Middleofnowhere USA
I personally wouldn't put water in it. That's the last thing I'd do.
Perhaps I would disassemble it and clean everything, but it's a ~$20 HF tool. I'd more likely just shoot a spritz of silicone spray lubricant in the end a few times while pumping it back and forth a bit with it tilted down so it can drain out. Put it away and hope for the best next time I need it. Silicone will help clean and preserve any rubber seals inside. I suspect it would be fine.
P
petee_c
Wheeler, Didn't see your post til now.
I did a dozen pumps of tap water through it, and then pumped it dry.
I squirted a couple squirts of rust proofing spray that is supposed to be safe for rubber in the suction end of it and pumped it a couple more times.
Yeah, no big loss if it doesn't work other than the fact the nearest HF is 2 hrs away and a border crossing for me...
It holds suction fine right now so hopefully it'll work the next time I need it.
Sent from my LG-D852 using Tapatalk
gungatim
west mich
just leave it. I've got fluid in mine many times over the years and never had a problem with it. it's probably good for the seals anyway.
bwringer
Indianapolis
I've never really liked speed bleeders for motorcycles. They're completely useless for bleeding air, and even just for changing fluid, it takes a tedious amount of pumping. Vacuum bleeding is faster, IMHO. YMMV, of course -- a lot of people like them.
I installed a large translucent plastic fuel filter, I think it fits an old Gold Wing or something, on my vacuum pump on a short piece of tubing. It gives a little more vacuum volume so I can pump it up once and bleed more, plus it gives extra time to spot brake fluid headed for the pump.
mbshop
visalia ca
For motorcycles I used pressure to force fluid up to the reservoir. On cars I pressure bled from reservoir to calipers. I gave up on vacuum bleeding back in the early 70s. To prevent contaminating the pump again, use a foot or so of clear tubing so you can see if fluid is headed for the pump.
