HF spot welder
gorilla
I have a one time use for a spot welder and am considering the HF 110 volt unit. Anyone have any experience with one? Metal thickness would be about .187" three layers.
kabinenroller
S.E. Wisconsin USA
The HF unit will work for basic use. It is very heavy and awkward so it does not fit in a tight space. You might be better off finding a local body shop who has a professional spot unit and would be willing to do a small job.
I have a Lenco Spot, instead of two copper tongs to has two cables with stingers on the end. It is quite versatile, and works well on body thickness sheet metal.
gungatim
west mich
eastwood used to sell a spot welder tool that hooked up to an arc welder. IIRC, it was fairly inexpensive. don't know if that is an option for you, but just another option to think about...
joe_padavano
Northern VA
I have the HF 110V spot welder. I picked it up used at a swap meet. It works amazingly well. You need to ensure that the tips are properly shaped and aligned. Practice with clamping time to get sufficient penetration. I ran a number of test welds using auto body sheet metal, then tried peeling the welds part to check for penetration. I'm pretty happy with it, especially considering the cost. I can't speak to the ability to weld a three sheet thickness. You may want to consider the 220 v version.
Ericgst
.187" is 1/8" and is very thick. The HF unit claims up to 1/8" thick but I really have my doubts about its effectiveness.
LXCam
I used their 240 model to attach sheet metal flowers to my wrought iron gate fencing. It was everything that unit could do to stick what was 20 gauge to .120 wall tubing. I doubt that 110 volt unit will do it.
Gamble
CHITOWN
Get the 220v. THe 110v won't do what you need
I use the 220 HF spot welder for attaching hanger brackets to art work. It works well.
Nobody i know of makes different tongs for them.
G
gorilla
The project is welding the raingutters to the birdcage on my 63 Corvette coupe. The birdcage is two layers spot welded together about.157". The raingutters are about .050" and weld to the lower side of the birdcage. I have both MIG and TIG so I think that I'll just plug weld. Thanks for the replys.
LXCam
If you have coated the layers in weld thru primer the spot welder isn't going to work for ****, your better off plug welding this.
joe_padavano
Northern VA
I am wondering if anyone has any updates or new information on this welder ? I am thinking about getting one for auto body sheet metal but am wondering if opinions have changed since this thread was created ?
If you are asking about the HF 110V welder, I stand by my earlier post. Not one complaint. It has worked great for everything I've used it for, though I have not attempted to weld anything thicker that two sheets at about 16 gauge. I did make a number of sample welds when I first got the unit (since it was used) and peeled them apart. Excellent penetration. Again, be sure the tips are filed and aligned. You can control penetration by how long you leave the power on - look at the diameter of the red spot that forms from the heat. It takes some trial and error to figure out what the right time is, but once you do, it works great.
Smokeshow69
Thanks for the update. I had a feeling it would probably work for the lighter gauge sheet metal I am looking to weld. I think a lot of the negative reviews come from the tips not being aligned correctly or people not using vise grip spot weld pliers to hold the metal together. I will have to get one and get to melting metal !
ghnl
Mebane, NC
I have the HF 110V unit. It works OK for thin sheet metal (up to two layers of 18ga). The metal has to be clean and fit together well.
Plug welds with a MIG are likely stronger & easier though.
rsanter
visalia ca
I have a miller spot welder and love it.
Even that one needed some adjusting and tuning in (and tuning if the operator) to make really good welds for autobody work.
I have heard good things about the HF unit, they are pretty simple machines. You can expect to have a learning curve to learn to get really good and good looking results.
I wanted a factory appearance which is why I bought the thing. I had to buy extra tips and turn them on the lathe to have a larger contact area. Then to compensate for the fact that I have a much smaller machine with a much larger tip I learned that I have to pulse the trigger to build up the head in that spot without just holding the trigger and getting too much sink of the spot I am making.
The machine is heavy so using a cherry picker to hold the machine while,you are doing this will keep it steady for a good and good appearing result.
Yes I have tested my welds and they are as hard as the factory ones to break. I even had an incident where I was in an accident (not my fault) with a car I repaired and that panel scrunched and accordianed and the spot welds held
Bob
