HF Toolboxes Workbench - Phase 3
Steevo
43.49600, -112.04300
Now I see why loading the HF cabinets from the top was not a concern!
Mike
Yep, that little Clark lift comes in mighty handy. The price was right, too. My brother in law got it for me free from a customer that was going to scrap it. I had to buy a charger for $150, but that's a small price to pay for the convenience of a forklift.
Steevo
Looks great. Can't wait to see what top you have. Was thinking along the simiar lines, but not to remove the casters. Keep up the good work.
Smiley
I was originally going to try using boxes bolted side-by-side with tops on them, but the height would have ended up at 43", which is too high for me ( I am only 5'10").
Also, the boxes on wheels would be only as level as the floor and the quality/fit of the boxes (made in China), so I figured there would be three wheels on the ground and one not on each box, putting a lot of strain on things.
I also wanted a bench that had solid footing on the floor for pounding on stuff in a BIG vise. I was afraid that would cause fatigue to the boxes if all that impact over time was transferred to them.
By losing the casters, and putting them in a leveled frame, I was able to get the top down to just under 39" which is workable for me.
icecactus
Check the first page of this thread, where I provided that info. :)
Wtf... i looked through the thread twice to see if it was already posted. I even looked the other day when i first read your thread :headscrat
Apparently i need to open my eyes..:)
They got some cam lever things that i have been wanting too there...bookmarking that place.
EDIT: I did find the link, i was just stating that i looked before asking and didnt see it. Thx!
machine_punk
Napa Valley, California
I've been waiting to see these go from 'drawing' to real life...they look great. In fact, your whole workshop looks great so far. I'm glad you finally got the time to work on these.
DIM Fab
Keller, TX
Awesome work, Steevo! I just picked up one of these chests, myself, then found your thread. Perfect timing because I'll be building some workstations in my garage over the winter and spring. Might have to piggyback on your ideas a bit! Why reinvent the wheel when you can spend more time innovating on how to make it rounder?! ;)
Based on the pics, it looks like you're going to mount the bench tops well over the flat top of the cabinets - maybe about 1-2" because of the rolled lip that juts up around the sides and back of the cabinets? Are you going to do anything with that gap? Hinged tops? Special hidey-hole for flat tools? I've been debating on what to do with that area.
I've also been trying to think ahead about mobility. I like this solution, but the wheels would need little mounts that jut out, versus the setup this guy has, because of the srew-in feet:
Graham08
Iron Station, NC
Kabina got it right. The project tractor in the corner is a Bolens HT20 with a Johnson 14 loader.
I have seven Bolens and one Simplicity tractors, which is why I need the workshop and some storage racking for all my projects.
Cool tractor. I have an HT18, great machine. I need to find a snowblower for it.
Nice work!
Steevo
Finished the workbench today (except for a minor trim piece I want to add).
Set the frame in place and leveled it, dropped in a couple boxes.
Then a couple more
Then came the wood tops.
Then I put the steel tops in place, and welded the seams, corners, etc., and ground everyhting smooth.
I want to add a trim cap along the top of the backsplash, then screw the backsplash to the studs in the wall.
I am happy with it. It turned out just like I designed it on the computer.
Next project: A rolling workbench.
kv501
First one in to say how cool that is.
Bravo, man. I hope you don't mind me shamelessly ripping off your idea!
Great Job!
Steevo
Take any or all of the ideas. I have no patent on anything. :)
The space under the bench tops, where the gap is that you mentioned is lost space, just like the 2x2 area in the corner under the bench. I originally thought about making the frames shorter, so the lip on the boxes protruded above it, then routing slots in the bottom of the wood tops so they sat down close against the boxes, but that is a lot of work for nothing more than a bench that is shorter by an inch.
zruvalcaba
San Diego, California
Yeah man, great job. Now I know what I'll be doing! Quick question for you...maybe it was already asked and answered but can you let me know the height from the floor to the top? My current bench is 30" high and it's a tad too short for my liking. However I'm a short guy 5'7" so I don't want a 40" height either. :thumbup:
DIM Fab
Keller, TX
The space under the bench tops, where the bap is that you mentioned is lost space, just like the 2x2 area in the corner under the bench. I originally thought about making the frames shorter, so the lip on the boxes protruded above it, then routing slots in the bottom of the wood tops so they sat down close against the boxes, but that is a lot of work for nothing more than a bench that is shorter by an inch.
That rationale is aces by me. :thumbup:
Fantastic work! You managed awesome function and super classy form! :beer:
Steevo
I have had a couple of PM's asking about the cost.
I have no secrets, so here are the numbers:
Steel - Bench Frame $359
Steel - Bench Tops $387
Leveling Feet $121
Wood Tops (doors) $87
Welding Supplies $100
Spray Paint $22
Tool Boxes $1500
Total Cost $2576
NUTTSGT
Northern Central Ohio
Leveling Feet $121
Spray Paint $22
Tool Boxes $1500
Total Cost $2576
awesome workbench . . . . . . . priceless
fixed it for you. :thumbup:
Kabina
Pa.
Turned out Great. Thats how I plan to build my bench, along with another roll around table the same height to form the U shaped bench, talked about before.
Do you have pictures of the rest of your garage, you would share?
Steevo
Haha :) Good point.
Looks super slick Steevo, nice work. How did you fix the bench tops to the frames?
The wood tops are screwed to the frames from underneath.
The steel cap is held in place by gravity at this point (350#), but when I bolt a vise in place, it will be locked in place.
Nelson58
New York, New York
Fantastic job Steve!
Did you consider dropping the wood doors into the steel top so you have a wood top to work on with steel underneath? The wood gets grungy, you just pop it out and pop in a couple new solid core doors and you are good to go.
Nelson
1BADLS1tuner
Nebraska
Great Job! I really like that, I am going to do something very similar with my shop! Just have to finish getting it built first lol...
Steevo
Nelson
I am not sure why I would want a wood top. This is a machine work/metal work/equipment repair type of work area.
Steevo
Let's hope you lose nothing under those benches. They look close to the ground
Yeah, it will be a dust trap and a place for small parts to roll out of sight. I have thought about putting gray rubber base around the bottom to avoid that. I may buy a piece just to see how it would look/fit.
Steevo
Thanks to everyone for all the kind comments. I really enjoyed building this, since it will be my primary work area and tool storage for a long time.
NUTTSGT
Steevo, you said you were going to wax the steel. What happens if you get some heat (from a torch) on that waxed surface ? Think it'd smoke or anything ?
Steevo
I will use the thin clear liquid wax that comes in a can like mineral spirits does, that is used for iron stair balusters to keep them from rusting.
Once I start using it, it will get regular "treatments" with oil, grease, ATF, etc. which will keep it from rusting.
I'll have a welding table for the hot stuff, so the only place I may use a torch near the workbench would be on something in the vise, or to heat something to install/remove a bearing.
