HF vacuum gauge
mopar01
Angola IN
Tried seaching with no luck. Anybody have one? Is it worth it or should I. Buy a reptiable one? Thanks for you input.
Delray
Upper Peninsula of Michigan
You may want to consider a Mityvac. Check Tooltopia and/or Amazon for prices and models.
I'm thinking vacuum tool here. If you just need a gauge I think mine is a Lisle.
TJJP77
You can probably pick up a clean used MityVac on ebay for cheap, plus the MityVac is rebuildable if the need should arise. I've had my MityVac since the 1980's and it still works great.
ChevyEFI
Phoenix, AZ
I have one that's an Actron I think. Bought it 15 years ago; used for tuning carb. cars.
I also have a more vintage one. Neighbour gave it to me; it's a built-in carb-line pressure gauge too.
Still DD a carb car. But get far more use out of my mity-vac.
srmofo
SW ohio
Are you looking for the gauge or the pump?
I have a actron gauge, it works fine and was maybe $10.
HF cant make a tire pressure gauge, fuel pressure gauge, or air regulator gauge thats accurate, I really wouldnt trust their vacuum gauges either.
mopar01
Angola IN
Well I was llooking at just tthe gauge. Think in going to look into the mityvac though. Thanks guys
tube_guy
I looked at the HF vacuum gauge in the store. For roughly the same money, I ended up getting a really nice large dial Ashcroft vacuum gauge new old stock on eBay. It's not a compound gauge that also measures fuel pump pressure, but most of those are pretty worthless for anything fuel injected anyway. I just added some rubber tubing and some adapters for auto work. I also use it for other things like testing the fuel oil pump and supply line on our oil burner, so it's pretty useful.
skruft
I don't think it makes a big difference since it won't be used all the time. I most often use an ancient Sun dual vacuum gauge in a metal case, and a couple of vacuum pumps that have gauges. Also I made an automatic vacuum pump for veneer pressing, and on that I have two regular gauges that look like compressed air gauges. (Why two? So I can see the reading from different directions.)
