'Hidden' gun safes?
rayra
Escaped from Los Angeles
If you want to hide something large, it's best to hide it in what Douglas Adams referred to as a "Somebody Else's Problem Field".
Rayra has the right idea.
heh. thanks. yes, an SEP Field, something so odd that people mentally reject seeing it. Like a Chesterfield sofa hovering over a cricket pitch. Loved his books.
And its corollary, show people what they expect to see and they pay it no heed. A full bookcase, no one has ever noticed, even when I draw their attention right to it, asked them to look more closely at. Nobody figures out it isn't full depth.
Or the packing box facade. I weathered the boxes differently, made them look mildly rumpled and askew. Labeled them innocuously as 'bedding', 'old kitchenware', 'towels' and stacked stuff on top. The three boxes were just the same height as the safe. Piling more junk in that corner and it's a heap of **** few would bother with. The facade's sides only extend 3-4". In that dim cluttered corner it works great.
I also thought to do something similar with a wardrobe style moving box, even having the hand opening with the end of the sheet metal hangar rood and some metal hangar hooks sticking out, and with some scrap of clothing blocking the hole itself from the inside. 'mom's clothes'.
But it wouldn't have been tall enough for my safe.
Same with the tops of bookcases or tables, trimmed with crown mouldings. The mouldings can readily mask a hidden depth. Build a tray-like space in the top, make the top a removable cap, held in place with some rare earth magnets. It will resist mild tugs and bumps but a firm pull lifts it right off.
pablo94sc
Memphis
Put simply, the object should appear so common as to remain entirely unnoticed by an average mind; an object that is invisible in life, either because we've learned to assume it's present, or because it's presence doesn't adhere to our understanding of an environment.
This is an incredibly valuable concept. Adams created it as a satirical joke, but I've used the idea to great effect in many environments. It's also great for pranks. :D
Here is something to ponder:
What is it that people so readily expect to see in a garage that they simply will not see it? In other words, when someone walks in, the object is essentially invisible.
I don't mean your garage or shop specifically; I mean an average garage in your neighborhood. Remember what people are like, and how garages are wasted.
Garbage cans, old shoe boxes, metal shelves, my f'in screwdriver that I just had in my hand a second ago?
bushmechanic
I saw your post and pictures after typing that, and immediately wondered if you were familiar with that part of the story. :lol:
Either make something exceedingly common, or exceedingly unbelievable. The mind must either accept or reject the reality of the environment and create it's own comfortable set of rules.
That's all it takes to hide an object.
NUTTSGT
Northern Central Ohio
But I'm concerned about a fire and whether the gun safe my fall into the basement and possibly crack open or the frame get bent and the thing now fills up with firefighter water. The location against the corner of the closet is against an outside wall and a garage wall, both with concrete basement walls underneath.
What do you guys and gals think? Am I over worrying about this?
What do the firefighters out there see? Do the heavy gun safes fall into the basement?
****, I have seen a kitchen stove fall half way through a floor after there was a fire directly underneath it.
If you have a fire, let the OIC know where the safe is so they can keep a hose line on it and in the area. Hopefully that should keep it cool and prevent further heat damage from the fire. If the structure is a total loss, it could still end up in the basement but hopefully it might be a slow collapse so it wouldn't be a hard hit into the basement.
Those of you with gun safes or just large safes upstairs, please follow the same advice and let the OIC. No need to have a safe come crashing through the floor injuring (or worse) somebody trying to save your property.
strada12
NW Indiana
My dad has his gun safe in the garage/reloading/hangout and was concerned about how to hide the torches as to not give the thieves any help,I recommended he just take all the torch tips and put them in the safe. how many thieves carry victor tips around with them?
kjdhawkhill
Flyover state #4
Reminds me of the movie "Shooter", in that it only takes one small part to make the most complex and destructive device (in this case torches and in the movie, a sniper rifle) into a large and complex, overpriced club.
NUTTSGT
Simple but an effective way to prevent your own torches from being used against your security measures.
drmarkr
Tucson
Curious how you put such a curve on the face of this. Looks great!
I clamped a fence at a 45 degree angle on the table saw and then fed the board across the fence.....progressively raising the blade until I got the cove depth that I was seeking....
CJM8515
I always feel building to be seen in plain sight is the key. A gun safe is a good idea, but it wont stop thieves. Most of those "locker" type gun safes a good demo or crowbar will make short work of. Friend of mine had a heavy duty browning safe that was in his garage and it caught on fire, things int he safe did survive and so did the safe.
If I was to build a hidden setup the bookcase is tempting. Whats even more tempting is a false wall in a closet or other such hidden panel. A false floor is also a cool idea. I saw online once someone had one of those step down areas and built a large landing into it. Well the landing areas front removed and it had a slide out in there to get to whatever you wanted to put in there
slip knot
Texas gulf coast
Nuttsgt, around here if you tell the IC that theres a safe with firearms/ammo in it, the Fire crew will back off and go to secondary containment while your place burns to the ground. I've seen this twice now. Not exactly sure why but have seen it with two houses.
ekimneirbo
Kentucky
Search Craigs list for used "armoires". People paid serious money for them years ago to hold their TVs, and now they just want to get rid of them. I bought three of them and put shelves inside to make bookcases. They look really nice and you might use the face of one to conceal a gun safe if its sitting back in a recess. I paid between $75 and $150 for them. The original buyers paid $1500 and up for them. Mount the gunsafe in a recess and then place this in front of it . Put shelves in and store wine and party stuff. Roll it out when you want to get in the safe.
Heres an example near me.....$70 and no one has bought it .https://louisville.craigslist.org/fuo/d/elizabethtown-computer-desk/6956124713.html
