Hiding wires in plain sight?
digdug18
Danville, PA
I need to run some under cabinet lights, there is no way to hide the wires behind the wall, could you give me an example of how to hide the wires? Are you just painting the wires, or running a conduit to get them out of plain sight?
Andrew
rockwithjason
Las Vegas
if you don't have access to the wall cavity behind the cabinet you will not be able to hide the lighting cable. you could run surface conduit and paint it but it will still stick out.
D
digdug18
Danville, PA
I want to make it less obvious is all really, I think some plastic conduit might work, but need to find pictures to make sure first, before I spend the money really.
z28toz06
Connecticut
If they are under cabinets, you won't see them unless you are bending over looking at them. (unless you are 3 feet tall. You could probably use some type of wood molding and hide them with it, like corner molding.
Traditional hotrodder
MI
Perhaps you could run the wire along the top of your cabinets then drop thru your cabinet where ever a light would be. I'd rather have an exposed shielded wire hidden inside a cabinet than in plain sight.
danski0224
Near Naperville, IL
Add some 1" millwork to the front of the cabinets, on the bottom of the face frame.
Cabinet bottoms (underside) are usually recessed about an inch from the face frame. Drill holes for your BX in the sides of the cabinet, as high as you can without going through the bottom.
As hidden as you can get.
Tsunami
KY
Try some LED lights, may cost a little more, but hey they last for a very long time, use very very little power and don't create any heat. Extremely small form factor with tones of light. They can be chained together to spread them out under cabinets/counters. IKEA has a good selection.
