I'm wondering if this is done, might work or be practical.
Air compressor with on/off at 120/160 feeds two tanks each with inline check valves, big tank has regulated output 110 psi with output to a Y from the small tank and then a final regulator to 100 psi or whatever shop pressure is.
No load both tanks fill to 160 psi.
Modest load the air comes from the smaller tank, when the compressor kicks on it sees a 120 psi head until the small tank comes up to 160 psi.
100+% of compressor output load, head is the small tank pressure, and big tank maintains min pressure to shop regulator.
Size of the two tanks and exact pressures adjusted to balance lower head pressure vs cycling frequency. Some kind of smart controller could also set min time between compressor starts forcing use from the big tank when cycle time is below the min.
