Hi-Lift Jack Specifications
•Approximate weight: 30lbs (14 kg)
•4,660 lbs (2113.74 kg) rated capacity
•Tested capacity 7,000 lbs.
•Climbing pins of specially processed steel with 125,000 PSI tensile strength and 100,000 PSI yield.
•Steel bar is manufactured of specially rolled extra high carbon steel with 80,000 pound minimum tensile & carbon .69 to .82.
•Steel handle of 14gauge high-yield structural tubing with minimum yield of 55,000 PSI. 1 5/16" diameter x 30" long.
Be sure to hold onto the jack handle tightly. I can't remember how many people I've seen who let the handle slip out of their hand and had a black eye, swollen face or worse.
I used to use them often to raise cotton trailers and would be bumping the capacities .....and as someone else mentioned, the higher the jack is, the less trust I would put in one. I have one that the main piece of the jack has a slight bend from getting it too high with too much load.
