Thank you all for your thoughts. If you all become woodworkers, you will use fractional measurements, I firmly belive. I came here to ask because of the generally high knowledge about tools around here.
I have bought inexpensive digital calipers more than once. Not using them often, every time I needed them the battery was dead. Worse, they never lasted beyond a few uses. The really good digital ones like Mitutoyo are more than I want to spend.
To sum up, after another half day of searching the interweb, I've concluded that indeed, there are no fractional dial calipers made in the US, Europe, or Japan.
Looking at only five pages of results from an Amazon search, and a general google search, from what I found, that leaves (pennies omitted, all made in China and all on Amazon except the HF) Starret-110, Igaging-34, Oshlun-39, Shop Fox-43, MH Global-29 (with 2 duplicates with different names, same caliper, about the same price), Harbor Freight-24. There may be others but I think I got most of them.
On Amazon, there is a Woodcraft fractional caliper implying made in the US -84.
The Shop Fox looks the nicest to me, and has the best reviews. The machining seems better, as evidenced by the better-machined knurling around the bezel. The MH Global, which has no reviews at all, is the only one that has the decimal scale on the outer edge and the fractional on the inner edge which seems more sensible and useful. However the tic labels on the inner fractional scale are in 1/8th, instead of 1/64th, increments, which makes it harder to read than the Shop Fox for fractions. The outer decimal scale on the MH Global is easier to work with than the inner decimal scale on the Shop Fox but that difference is less significant than the difference for fractions.
So I ordered the Shop Fox. I will have both decimal for my mechanic stuff and fractional for my woodworking. I also found a metric one, that I intend to get later: Chicago Brand 50012 0-150mm, .02mm gradations. It's shipped and sold by Amazon as is the Shop Fox. Despite good ratings on Amazon, which I am somewhat skeptical of, it's good to know that if these are not satisfactory I have a month to just send them back.
Thanks again.
