high quality tire plug kit?
Honda-Mech
I need a good tire plug kit for work. So far all the.ones I've looked at are very cheap. The Matco/ Astro Pneumatic version is known to have a cheap reamer that breaks. My Matco guy has yet to have a complete kit to sell me as he.keeps robbing the kitS of the reamer for warranties. Snap on doesn't appear to make a kit. All others I've seen are plastic handles. Who can recommend a metal handled durable kit? Thanks guy
maddawg1952
Peabody.Ma.
From their web site...the best truck tire plug kit available....safetyseal.com Call 1-800-888-9021 to Learn More
About
Contact
ORIGINAL SAFETY SEAL
THE LIQUID PATCH
Distribution
Español
Why Safety Seal?
Military/Government
OTR Tire Repair Kit
Tractor and Implement
Catalog
Log In
Blog
Original
Safety Seal
Kits
Auto Tire Repair Kits
Truck Tire Repair Kits
Off Road Kits
ATV Kits
Heavy Equipment Kits
Kit Replacements
Off Road Kits
ATV Kits
Safety Seal
+Plus+
The Liquid Patch
Safety Seal Plus Kit
Safety Seal Plus Replacements
Tire Repair Chemicals
Bead Leak Sealer
"Seek a Leak" Leak Detector
Safety Seal® Lube
Mounting Lube Concentrate
"Safety Coat"
ACCEPT ONLY THE ORIGINAL SAFETY SEAL® - Because all flat repairs are not created equal.
Safety Seal® is available in various sizes to repair all tubeless tires, from small tires to large Heavy Equipment tires. Each Safety Seal® kit comes complete with everything needed to easily, quickly, and permanently repair all tubeless tires...no cement needed.
A Revolutionary Concept in Tubeless Tire Flat Repair.
Installed on a dismounted - inspected tire this system incorporates Two “STATE OF THE ART” Repair Components.
Liquid Patch- which creates a permanent flexible patch on the inner liner.
Safety Seal Repair-Which Seals the injury from tread to Inner Liner to Create the Perfect Repair.
Original Safety Seal...Imitated but Never Duplicated
Safety Seal is superior to any other "on the wheel repair" tire repair on the market today!
What makes Safety Seal® different?
•24 plies of a custom made high tensile (350 lb break strength) chemical resistant nylon yarn
•Each yarn is immersed in our unique proprietary rubber sealant system-250% rubber to yarn
•Our patented manufacturing process assures the final Safety Seal repair has an equal amount of rubber sealant (250% rubber to yarn) through-out the Safety Seal Repair
•Superior tools to aid in the proper insertion of the Safety Seal repair into the puncture
©2013 Safety Seal. All Rights Reserved.
Website designed and developed by Sperling Interactive.
shockwave
Marietta,ga
Contact local tire distributors they will get a better deal on these. Safty seal is best for plugs. Just make they have the chrome reamer and insert tool not the plastic one
zakmartin
Seattle, WA
Murphy4570
West Deptford NJ
Odd that you say that what your Matco guy sells is junk.
The one I bought off my Matco guy many years ago is the Black Jack brand, and it has steel handles. Very robust and strong.
From looking at their website, it seems that they sell a bunch of cheapo plastic handle kits now. The only one that looks like what I have is this one:
http://www.blackjacktirerepair.com/kt-20sc
It seems that Matco currently sells this kit, which seems similar:
http://www.matcotools.com/catalog/product/TR45KIT/45-PIECE-TIRE-REPAIR-TOOL-KIT/
Here's a photo of what I have, part # BJK40:
BeachBoy
I have a safetyseal in my truck for off roading.
Best kit on the market.
G1GRANDEUR
I don't know what's so special about expensive kit, but cheap one never failed on me.
jeepinerdeep
South Central PA
I did some searching online and this looks killer.
http://powertank.com/products/sfID1/21/productID/529
I have that kit in my Jeep. It's pretty nice, but the plugs I replaced with Blackjack plugs. ( originals seemed cheesey, not sticky ). The handles and reamers aren't quite as nice as the Blackjack, but it's good for the trail. I carry extra Milton cores in the pouch too. I keep a Blackjack set in the shop.
Farmall450
Marengo, Illinois
I might have to cough up the $$ at this rate. :beer:
joecon
The best plugs are Tech plugs their rubber not fiber and they become part of
the tire and will not dry out or pull out after years of use. We always got them
from NY tech supply. Once you use them you will not go back.
trackwelder
n.y
Tech tire is what I prefer. I use to get mine from the NY tech supply guy also.
SMKS
USA, planet Earth
Safety Seal is what we used at the tire shop I used to work at.
I recently tried the made-in-China Slime brand plugs from the auto parts store and got a leak. I replaced it with a Safety Seal brand plug and it held for many thousands of miles until I replaced the tire.
btbsandman
Missouri
COO of Safety Seal?
Bloodystumps
Toronto Canada
Yup Tech is by far the best plug on the market. I've never had one fail, Those cheese string plugs are just temporary to get you around the block.
The matco one (black jack) the tools are good but the plugs are just cheese strings.
BillK
Beautiful Southern Maryland
Honda Mech ?????
I really don't want to take this way off topic but ..... I cant believe you are even asking this question if you work at a Honda Dealer. I might be wrong but the only "authorized" repair for modern tires is done with a plug patch from the inside of the tire. I bet if you go to every tire manufacturers web site you will find that all of the kits mentioned below are basically forbidden.
Now if you just want it for an emergency type kit to have in your own car, I could understand it. Maybe ?
Sorry for the rant but it bothers me that my Sister or a good friend could take their car to your shop and have un unsafe repair done. When it comes to anything safety related either do it correctly or don't do it at all.
Just my opinion,
wafrederick
Holton,Mi
The rawhide plugs are junk and don't seal worth a ****.I have pulled them out replacing them with rubber plugs.
c-hawk19
Spartanburg, SC
I have this same kit that i got at my local tool store. The tools in this kit are great.
trever
Oak hills ca
I had the cheapo green plastic kit on the first page the handle broke and the metal probe almost went thru my palm. Now have black jack kit and love it.
redmondjp
Redmond, WA
Whatever you do, don't ever buy the tools with the screwdriver handles - those are absolutely worthless. I have a couple of the plastic T-handle auto parts store kits and they have worked well for me, on both car and riding mower tires.
chris6278
USA
This kind of looks like the grip on kit i got off amazon several years ago. May or may not be the same but ive used it quite a few times and never had a problem with it
SMKS
USA, planet Earth
Honda Mech ?????
Just my opinion,
You're correct that the RMA (Rubber Manufacturers Association) guidelines say both the path of the injury and the inner liner should be sealed. Often, that would mean this type of repair.
But tire plugs are not really an unsafe repair. Saying they're unsafe is a little bit of an exaggeration.
One of the tire shops I used to work in installed both plugs and patch/plugs, so I've personally repaired many tires using both methods.
However, these days if I'm paying the shop price for a tire repair I would want a patch plug. I do plug my own tires, though, because I know how to properly use plugs.
And if I were a shop that was concerned about opening myself up to liability, I would probably only install RMA approved repairs and charge customers accordingly. That's not to say patch/plugs are foolproof. They can and do leak because of improper installation or time.
H
Honda-Mech
Hi folks. I will be trying the Blackjack kit. Sad that I cant even count on the Matco truck to have tools that dont break often. I didnt realize plugging tires was illegal, and still cant find anything definitive on it. My last car had a plug in each tire, and they outlasted the tires. We often get customers who come in and want to be back on the road in 15 minutes. Most of the time we try and sell a tire but that increases their wait time to over an hour. From now on though I think I may cover my *** and use the patch kits we have and tell the service writer to tell the customer its going to be 30 minutes, if it can be patched at all.
SMKS
USA, planet Earth
I've never seen any evidence saying tire plugs are illegal. This is one of those situations where people throw around the term "illegal" when it isn't warranted or accurate.
At least one state has considered legislation saying it would be illegal for a shop to install a tire repair that wasn't RMA approved, but I've never seen a state that passed one of those laws. (Someone is free to correct me if they can find an example, but I've looked).
Are tire plugs the method of repair endorsed by the trade association representing tire manufacturers? No.
Does that make tire plugs "illegal"? No.
More info on the RMA guidelines here:
http://www.rma.org/tire-safety/tire-repair/
SMKS
USA, planet Earth
Here's another thing Safety Seal sells that I didn't know about until just now. If I were in the OP's position and I wanted an RMA-approved tire repair that was quick and easy to do, I'd give this a shot.
Safety Seal now offers a two-part kit that they say meets the RMA tire repair guidelines because it also seals the inner liner of the tire. But it's easier than the patch/plug I previously showed because it doesn't require buffing the inner liner of the tire.
Buffing the inner liner is the part of tire repair that is the trickiest and the easiest to screw up. Being able to skip that step is a nice option.
http://safetyseal.com/safetysealplus.php
volleyball
NY, not NYC
My plastic screwdriver handle tool is over 40 years old and still going strong.
There is no one plug that is best for all tires.
Some types that people here mentioned as worthless have worked great and outlasted the tires they were on.
Astro_Pneumatic_Tools
South El Monte
I'm glad you brought this up, we've recently completely changed the base alloy and heat treating process on the reamer and plug tool.
Originally they were bending (too soft) so we increased the Rc a few points and suffered more breaks in the field, so we started over.
The reamer now has at least a 265% increase in tensile strength and the plug tool a 200% increase both without fracture.
We've already replaced the stock on these tools. Tell your Matco guy to request some free samples from us:beer:
__________________
Chris P.
Product Manager
Phone# (800)-221-9705
image.php
Ed ke6bnl
Agua Dulce, Calif.
I like this one a lot.
CJM8515
I have both the cheaper slime like kit (came in a yellow plastic case from walmart) and I have a blackjack which is identical to safety seal (Ive used both). The metal reamers and tool work way better than the plastic stuff. But the plastic stuff is ok for most things.
I buy my tire plugs from my local parts supply, they are not the cheapo junk that comes from walmart or the likes. Ive plug thousands of tires over the years (used tod o it when driving a flatbed) and only stopped b/c of lawsuits and AAA not allowing us. I have one failure in all those years and it wasnt the plug but the spot the hole was in.
bonneyman
Desert SW
My local tire shop no longer does the pull-thru kind of hole repair and gone to pulling the tire off the rim and putting a patch on the inside.
I have a fairly cheapo pull thru set just in case I'm stuck and need to get going. Don't know the brand.
BillK
I don't think anyone said they were illegal, but they are certainly "not recommended" by all of the tire manufacturers. Ask your Garage Keepers Liability Insurance carrier what would happen if one failed and someone got hurt because of it. Then decide if you want to use them or not.
I am going by the assumption that the o.p. works at a Honda dealer because of his user name. If that is the case I cant believe that Honda would approve that type of repair either.
