High storage / library ladder on steroids?
jmiller_2308
Shakopee, MN
Howdy. I've been a lurker until now but after reading all the good comments I thought I'd share my current wild *** concept to see if anybody might have solved this already or at least be able to add comments.
I'm working on some details on a garage addition that is about 850 sqft with 13' ceilings to accommodate a lift. I want to add room for bulky storage and was originally going to use attic trusses to create that storage but I decided to abandon that because:
  • I hate pull down ladders for access to the space. They are too flimsy and too narrow and I haven't found any that go 13'.
  • I looked at stairs but they cost a bunch and more importantly eat a LOT of floor space.
  • Realized that for most of the year the attic will be really hot or really cold. This is something I hate about the storage I use in my current attic.
  • Realized that with a 7/12 pitch hip roof and the dimensions of the garage that the usable space isn't all that large to begin with and when you start taking away additional room for access the cost of the space is really quite expensive.
That led me to the idea of using about 30' of wall space out of the way of the lift to create a 4' deep shelf 8' off the floor. This and another 80 sqft area would be only a little smaller than the attic trusses would have provided, remove the cost of attic trusses, and keeps the stuff on the shelves in a climate controlled area that is easier to reach. And it is that "reach" topic that this posting is all about.
I could use any old ladder to get up to the shelf but I'm hoping for something a bit more secure and easier to use. I could get a rolling ladder but they take up a lot of floor space that I'd hate to lose. I thought about ships ladders and other such fixed ladders but that doesn't work for me. I think having the ability to move along the 30' wall would make placement of bulky items a lot easier so fixing the ladder in one place really isn't useful. The idea of moving along the wall leads naturally to a library ladder but the problem with a conventional library ladder is that they tend to be very steep and narrow and not something I want to carry bulky stuff up.
So the current concept is a library ladder on steroids. I was thinking of making stairs that would be 12' long which when rested against the 8' shelf should yield an angle of only 42 degrees. I would make each stair tread 6" deep and 3' wide. I would put locking casters on the feet of the stairs and use some sort of rolling mechanism on top so that I could easily roll the ladder along the wall.
The biggest issue is that when angled the bottom of the ladder will go almost 9' into the working space of the garage so leaving it at this angle is unappealing. To address this, I thought it would be good to park the ladder in a full vertical position when not in use. Essentially I'd push the ladder toward the shelf until it is fully vertical. The lower casters should allow it to push easy but to be safe I'd like to have the ladder captured so that it couldn't topple back on me as well as to hold it in the vertical position without a chance of it accidentally deploying. I have some ideas that I'm still working on to accomplish this capture but any ideas from others are certainly welcome.
One final thing that I'd like to do is to be able to move the ladder to use as access to the other 80 sqft of 8' high storage area that is in the same garage. This complicates the rolling and capture mechanisms. I'm also concerned that this thing would weigh significantly more than a conventional ladder so moving it off the rollers may not be all that easy.
Here is a picture of the garage. The lift would be in the additions upper right corner.
Jeff
MillerMav
I'm going to keep an eye on this for sure as I am dealing with the same issue.
Good luck!
Rarely am I not posting from my phone....
J
jmiller_2308
Shakopee, MN
It is too late to be building this year so my addition won't start until spring. I'll try to be sure to draw up my ideas with some detail before that happens.
Here are some other details that I continue to explore for the "parking" area. The parking area would have something running horizontally about 2' above and below the shelf. The top horizontal would be the ladder width into the garage from the shelf while the lower horizontal would be in line with the edge of the shelf. This should allow me to push the ladder in and prevent it from going too far or falling backwards onto me. I'm still pondering how to capture the ladder. A simple hook would work to capture against the bottom horizontal but I'd still need a way to lock it in place with something other than the locking casters. A latch with a rope that I can pull to release might be the answer; something like an emergency release on a garage door.
I also did some rough calculations for weight and if my numbers are correct this thing built out of wood will weigh about 150 pounds. I think that will be manageable but it would be nice if it didn't weight quite that much. Most of the weight is in the stringers so if I can swap out for lighter material (aluminum?) that might be appealing.
Jeff
onething
TEXAS
I dealt with the same issue in my old shop and never did anything. I had a couple of thoughts, though. I planned to have a short wall parallel to the loft that formed a pocket the ladder could be shoved into in a vertical position - like a pocket door.
To have access to all of the loft, what about a curved front lip instead of the angle you showed? I've seen library ladders that would follow a curve.
I'm subscribing so I can see how it comes out...
rsanter
visalia ca
If you haven't built the garage yet...then think about installing an I beam that can heva a trolly and hoist on it. Use that to put thinks up there.
I like the mobile stairs and then store the outside perhaps.
Or have the mobile stairs also be a mobile storage shelf for stuff that isn't too heavy but you want to have easy access to
Bob
akdiesel
Wasilla, AK
onething
Here you go. My build is very close to what you are wanting. The library ladder and all the components are made out of Unistrut. My ceilings are 12'6" tall and the upper shelf on the bench wall side is 94" tall. The bench wall to the edge of the overhead door is 4' deep, so with the bottom of the ladder is just past the door opening. The jib cranes also help to lift heavy items into the storage or the shelving above the cabinets.
You will have to scroll through the pages to find the ladder and the other items in question.
http://garagejournal.com/forum/showthread.php?t=171590
J
jmiller_2308
Shakopee, MN
One of these with a couple of sets of hooks to hold it in position while in use and to hang it for out of the way storage-weight is 20-25 lbs.
http://louisvilleladder.us.com/products/specialty-ladders/fiberglass-en-2-3-4-5-6/fh1000-series.html
I was thinking about using an aluminum ladder instead of building my own. It would certainly be simpler and easier but in the end it is still a ladder that has narrow treads that aren't very deep and it sits at a fairly steep angle. This doesn't bother me for access but I'd like something a little more sturdy when hauling bulky items.
Jeff
J
jmiller_2308
Shakopee, MN
Bob
You know, I kind of like this idea. The drafter is beefing up the trusses to support the load of the shelf. He hasn't given me point loads yet but I like the idea of the trolley and not having to carry stuff.
Thanks.
Jeff
toomany
Auburn, Mi
I've got a couple ideas on how to get the ladder vertical and not have it fall back on you.
A pair of rollers on a track along the length of the wall. From these rollers, another pair perpendicular (90*) to the first. The second set would have to be offset a little away from the wall I think. On the second set or rollers a track (similar to a garage door track) could be added. This would allow the ladder to pivot out and away from the wall and still be captured at the top. You would need room above the shelf for the extra length of the ladder when in the stored position. It makes sense to me, maybe I'll try drawing up something real quick to help explain it.
Or and even simpler idea. Have your track along the length of the wall with the ladder hooked to it with a set of pins that will let it pivot. Get a hoist and mount it to the ceiling. When you are done using it, return it to the park spot and hoist the lower end up. You would need clearance in the arc that it swings, but you need that with attic stairs too.
oldcpecdr
Cape Cod
I am on Cape Cod and a lot of the buildings here are cape cod style homes, or saltboxes so a matching shop fit right in... why not do what I did and just make the shop a few feet wider and add a real staircase to a real second floor, I have a full dormer across the back so a full size shop upstairs also with the previously mentioned I beam and trolley to lift the heavy stuff up I also built a "real" stair case up to the third floor loft area just for storage.... A LOT safer than any rolling or folding ladder.
Mike B
J
jmiller_2308
Shakopee, MN
onething
WOW and OMG :eyecrazy:
I was at that thread earlier and didn't scroll down far enough to see all of your work. Thanks for pointing me to it. I'm going to need to study that for a long time to see how many great ideas I can apply to my shop.
Jeff
J
jmiller_2308
Shakopee, MN
Mike B
Several factors including height restrictions, set back requirements, tree impact, dirt work, and of course cost ultimately led to the current design without a real staircase.
The first guy that came in with that kind of a concept turned pale when I told him my budget. He came back with something very similar to what I posted without shelfs, unfinished, no electricity, no sheetrock, no insulation, just a roof and stucco on the outside and it was still in excess of $87,000 :eyecrazy: or about $140 sqft. I can only imagine what he would have wanted for the larger staircase version. :sad:
Jeff
kbs2244
First, I think 4 feet deep is too much to reach to the back from a ladder.
I would go with 2 feet max.
Second, library ladders were designed for libraries. To carry books up and down.
Even a big book is pretty small and light by shop storage standards.
You ladder design is good for getting you up there, but I think you need a rail and hoist system to get your stuff up and down.
vwracer
Linn Creek MO. 65052
Just some advice from a old guy that has been climbing ladders for 35 years cleaning windows for a living. If you do not have a lot of ladder experience DO NOT carry heavy stuff up to your shelves! it will be like monkeys screwing footballs. GK
CasesCustoms
How about an adjustable ladder design that is attached to a rail at the top with a pivot point. You can extend the ladder length and pivot it out to achieve the 42 degree angle and collapse the ladder and let it hang vertical.
I am thinking of a ladder similar to the one below but only using one side and attaching the pivot point to a rail.
http://www.homedepot.com/p/Werner-1...e-IA-Duty-Rating-MT-17/100658952#.UqdQRPRDvB8
If you want a wider version then you could just use the overall concept but fabricate your ideal width/step configuration.
ChevyEFI
Phoenix, AZ
Good thinking, I'd say. Add wheels for lateral movement and figure out a sliding upper setup. But since that style Werner folds the two sides flat against each other, why not use it in-position and leave it there as it's storage place, perhaps flipping it up parallel against the ceiling?
FWIW, I got a pretty good deal on a Werner from Amazon's warehouse deals.
