High thrust caulking gun... Mistake?
mike93lx
Richmond, VA
So I bought a tool without thinking about it too much... Yeah a shocker to this group.
I have a cheap quart caulking gun that works as well as cheap guns usually work. I have a project coming up that will require dispensing 12 quart tubes in short order. I couldn't justify a powered gun, so I bought a high quality JES. I grabbed the 26:1 instead of the 12: thinking more power must be better. It seems very nice, but I realized when opening it that high thrust means short travel...
Side by side, my cheap one looks like about 2x the travel, so probably close to 12:1
Which is the right answer? Not sure I could get the 12:1 by the time I need it Saturday, so it may not matter, but I figured I should ask anyway. The material won't be all that cold but I don't know how soft it is (green glue).
barnonline
Denmark
Unless you are usually using a soft caulk/a thick bead I personally prefer a high thrust gun for allround use.
I prefer the situation where I do a lot of fast easy squeezes with a high thrust + soft caulk than the opposite scenario with very hard squeezes with a low thrust + hard caulk
matt_i
Setup a hot box (space heater or 100W incandescent in a cardboard/plywood/cooler) and get the stuff warmed up and it will flow. I havent' found anything that didn't flow noticeably better at 90-100F.
A cordless/Li-ion battery caulking gun will outdo any human when it comes to dispensing.
mike93lx
Richmond, VA
This is a situation where control isn't the concern. I just need to get 2 tubes of glue spread on each sheet of drywall. Speed is probably most important, but I was thinking the high thrust would be easier on my wrist and forearms.
I think the high thrust will be useful for subfloor, which was why I bought a guart gun in the first place.
Plus the JES just feels like a high quality tool. Cast handle and the barrel feels very strong
mike93lx
Richmond, VA
Well, the gun worked great, but so did my cheap one. Green glue is really thin. It was helpful to have a second gun anyway as I had a buddy helping.
On one of the tubes, I didn't cut all the way through the nozzle and the high thrust gun had no problem blowing out the back of the tube. A lot of power with that gun.
Either way, the JES is really high quality. A little heavy, but very well. Built
