I was doing some field work on the commissioning of a power system for a particular airport's new train system.
The particular system I was working on was the "shore power" for the cars sitting inside the garage. This powers the climate control, door systems, ect when the train is not feeding from the 3rd rails.
The voltage is 750V,DC, and there are two disconnects at the location: A manual lock out switch, and a contactor. The contactor is controlled by a train line connect circuit, it won't close until its plugged into the train and a circuit is completed.
So, in theory with the plug un-plugged there should never be any power, but the only isolation from the 750vdc is that contactor (and numerous procedural safety's).
The point to my story involves why I was there in the fist place. Apparently, one of the union sparky's decided he wanted to stick his fingers into the socket???? Of course in theory it should be open. But in reality because of a few details I can't get into there was actually a voltage there, and he got zapped! Luckily it was just bleed through with no current behind it so he didn't get hit with 750 (or he would be dead).
Why would a trained electrician, working on known high voltage extremely dangerous systems tempt fate like that?
Just goes to show, NEVER get to comfortable with electricity. Though I did fail my own rule when I was working on the system, I didn't verify power off with a multi meter after we went through all the disconnects. I didn't do this because someone else just had his hands on the dead bus, so I figured since he was still alive I was ok.
