High water alarm
gizardlizard
Madison, WI
Could someone recommend a high water alarm system they like and trust? I want low voltage sensors that are hard wired (not battery operated) and WiFi so my phone would alert me of a high water condition. Lots of reviews I’ve read, people complain about connectivity issues. Anyone have some brands and models they trust? Looking to monitor a sump pump pit and a floor drain in a finished basement.
usa#1
Check out YoLink products. I've found they have an exceptionally long range. Check on Amazon for their product line. I've been extremely satisfied with them. I currently have 4 of the water detectors and they work great. Sorry these are battery operated, missed the hardwired part. However the batteries last years in these YoLink devices.
kbuhagiar
Escondido, CA
I've had great success with MySpool products:
Higgins
Shepheardsville, KY
Wow
Wish I had know of them sooner…
We had some nasty storms in KY recently lost TWO sub pumps and the basement flooded….
So it’s going to be a long road to recovery as both my wife and I are in our 70s
It would appear that there was some sort of electrical issue as we lost other devices in the house and garage.
We do have a hole house generator, and the pumps it turns out are on the same circuit. So that eliminates both pumps failing at the same time….
Higgins
Shepheardsville, KY
Wow
The good news is we have sub pumps insurance. The down side is it’s capped at $25K and doesn’t cover the cost of the pumps and is capped at $25k.
Looks like that will cover about half of the costs to get back to some form of normal..
Signed
I’m Tired
G
gizardlizard
Madison, WI
This looks super promising. Thank you 🙏🏻
engineer2
Chicago burbs
I use MySpool and they have been reliable. Chinese, but they have a support guy in NJ.
Get a version with float switches. Some versions have the water sensor grids and they corrode after a while. You can easily convert grids to float switches if they go bad.
I have dual 120 VAC pumps connected to two computer UPSs.
MySpool also makes a 3 input voltage sensor. It will let me know if house power goes out, if pump 1 UPS battery voltage is low, and if pump 2 UPS battery voltage is low.
BombShelter
State of Hockey
Unfortunately drain tile with a sump pump isn't waterproofing, it's water management. Most power outages are during rain events and a back-up system should be available. If there's a ton of water, more of a flooding condition, the sump pump system wont be able to contain that water if it's moving through larger cracks and holes.
I'd walk around the outside foundation and see if you can spot any of these cracks or holes at grade, especially around the downspouts. Even small hairline cracks can let in a ton of moisture with enough pressure. Have someone dig down a foot or two and repair these areas. Check window wells for trim rot or crack concrete, repair these areas and caulk up the sides of the window well. While this will help, an exterior waterproofer will be able to seal up the foundation further down.
G
gizardlizard
Madison, WI
Not sure who this message was meant to go to. 🤔
engineer2
Chicago burbs
Yes, it's water management. Newer houses with poured and sealed concrete foundations are pretty good at keeping water out.
Foundation leaks are a separate issue that need to be addressed. As said, caulk those window well sides and also cover them to keep rain out.
I'm an experienced basement flood fighter. Grew up at ground zero for flooding basements. One of the oldest companies in the business started in my hometown.
mm08822
While perimeter drainage at the footing is important, managing the ground water from downspouts or being on the low-side is really important.
Divert downspout runoff away from basement perimeter to distant low spot, storm sewer or street. Swails can also help. Topography is important for which options could be available.
Stuart in MN
Minneapolis
JKinAK
One option (but it’s battery powered) that’s versatile is from Ubiquiti. It’s a multipurpose sensor (but if configured for water sensing it looses other capabilities). Unfortunately the water sensor is only available as one of the three sensors in a 3-pack. The advantage is that you can check multiple types of sensors from one app. I use them mostly for monitoring door open/close status and it simultaneously provides temp, humidity, light, and motion sensing. You can also add cameras to the system.
Here’s the dashboard with 4 sensors and no cameras.
BombShelter
State of Hockey
I just assumed if your looking to monitor water in your basement that your having water issues. A properly waterproofed basement shouldn't need a sump pump but they can be nice for piece of mind and most basements are not properly waterproofed, more like damp-proofed. Most remedial "waterproofers" don't address foundation issues, let the water in, pump it out. Throw in a power outage and the alarms/pumps don't work unless you have a battery or generator. Sorry for the misunderstanding.
DGersic
DeKalb, IL
I’m tempted by the myspool water level monitor. It would be useful and interesting to know how often my sump pump is running.
DGersic
DeKalb, IL
Not all water issues involve basements. Some are not easily or inexpensively resolved. I have a somewhat unusual problem with water at my beach cottage that’s 1000 miles from home so I can’t easily check on things. Even just knowing that I have a problem allows me to send someone to deal with it if needed.
G
gizardlizard
Madison, WI
My house is situated in a very low area. My backyard is a protected wetland. The ground didn’t perk for my septic system, so I have a mound system on some adjacent property. In the early spring during the thaw and/or rainy season, my sump pump will have a run time of 15 minutes or more and might be off for 5 minutes at a time. It’s crazy how much water comes in. I’ve never had water in the basement but have a battery backup pump, along with a spare line voltage pump ready to go. The alarm is for peace of mind. My neighbor has it worse than me. His pump will run even longer cycles.
Tuhls
Not an alarm suggestion, but I installed a BLINK camera above a sump pit with a 9w (60w equivalent) bulb on 24/7/365.
I had a CSH Industries hardwired water alarm WA9-04-30 mounted on the main hvac plenum to be heard everywhere in the house. This was at my parents house, if the alarm sounded they notified me so I could look-in and with this early warning had time to react as the drainage tubes into the pit had not yet backed-up with water. The success of the system relied on somebody being home, but that was never an issue.
