Highest/ Tallest Car Ramps
Johnny A
mass
Hi All,
I'm looking for a set of ramps that will have the most clearance. I heard some ramps sold raise the front of the car 14 inches. I want drive up ramps that will allow me enough room under the front of the car.
Any advice will be appreciated.
Thanks in advance.
DetachedGarage
Wisconsin
Hi All,
Thanks in advance.
Race Ramps are a good option, but they are not cheap. https://raceramps.com/
You might be better off trying to build your own, but these are very nice and people use them at the track all the time in between heats. :thumbup:
Rod N
Keswick, Ontario
I think the problem will be getting the car on the ramps without spinning the tires.
I've had to jack it up and then you might as well use jack stands.
KEH
I have a pair of plastic ramps that raise the car 6 or 8 inches. I only use it for oil changes
in a Camry. It is possible to change the oil in that car with no ramps but better with ramps. The only issue is that the FWD Camry sometimes spins on the plastic ramp. I gave thought to pitting skate board tape on the ramps for better traction, but I can usually manage if weather is dry by getting a little head start.
KEH
Showkey
"MEMBER EMERITUS"
Wausau WI
My issue with ramps is storage when their not in use...............
I have used race ramps, but don’t own.
P0234
NoVA
Race ramps makes some 12" cribs but you need a jack, obviously.
mikegt4
sw ohio
Be aware that tall ramps often interfere with the bottom of fenders and front spoiler. My Focus just clears a 7" tall Rhino Ramp.
