HiKOKI Japan Voltage Requirements
Wamsutta
Amarillo, Texas
Some of their tools run on 100V and some of them run on 200V. Will the 100V requirement work with the U.S. 110 to 120 volt receptacles?
How about their cord plugs? Do their cord plugs fit into a U.S. style receptacle?
HiKOKI G15YE3 (180mm)
W
Wamsutta
Amarillo, Texas
So basically what you guys are saying is I need to plug it in in Japan and then run an extension cord from Japan to Texas. :)
F-22
Should probably be fine but stuff like this can be hard to tell. I think the frequency in japan might be different? Not certain. The 220v tools could also probably work on the US 220V power although at a different frequency...
Says 100vac and either 50 or 60 Hz, so tool probably fine on either
W
Wamsutta
Amarillo, Texas
I forgot all about the frequency! 😱
F-22
For simple motors it'll just spin at a slightly different speed. As long as there's no more complex electronics inside... Modern angle grinders do have certain systems like a slow start, so I'm not sure, but older ones should work on anything.
neophyte
Pennsylvannia
It’s a brushless motor, with the “fancy” electronics this would entail.
Grant Gunderson
Bellingham, WA
I’ve brought a bunch of electronics back and forth from/ to Japan over the years. There is absolutely no issues at all running Japanese electronics here or vise versa. The difference in voltage / hertz is too minimal to have an effect.
Only practical issue is Japan doesn’t use a ground on their plugs. Just a hot and neutral. So if you are taking a us grounded 3 prong chord to Japan you need a 3 to 2 prong adapter and that’s it.
