aka Larry
As some of you know, I built my own 4'x7' utility trailer a few years ago. It was designed to haul my tires and tools to the track, but is used for hauling whatever I need.
The construction material was overkill (again hindsight is a cruel b*tch) as I used 2"x2x3/16" angle and 2"x2"x1/8" tube for the tongue. So right from the get-go its heavy, and when load, I think the tongue weight is just too much. How much is too much? Well I haven't actually weighed it to see what amount is actually on the tongue, but having to lift it on the ball when it's not lined up exactly is a *****, and it causes the car's suspension to sag quite a bit as well. IOW, as-is I don't think the trailer's axle is carrying enough of the load.
Take a look a the drawing below that shows the dimensions. Notice the two load numbers (stuff in the toolbox, and tire/wheels) as listed. These are approx, but rarely do I have any weight further back unless I'm hauling plywood, mulch, etc.
I'm considering removing the fenders and axle hangers and moving them forward to reduce the tongue weight, but I'm not sure how far. Obviously it will not tow well if I move the axle too far forward. Thoughts from the collective GJ wisdom?
