Hinging sheet metal
motoretro
USA
Looking for a good method to hinge thin aluminum with a eye towards lightweight and simple.
Any suggestions? Thanks.
motoretro
USA
I'm building a small, approximately 3" by 3" by 3" aluminum enclosure for placing a Tangia alcohol stove into. (3) sided with two hinged areas. I want it to fold flat when stored. It's used for backpacking and bike trips. I don't have any fancy sheet metal equipment so want to keep it really simple in construction.
flyingblind
Washington
I would just use a piano hinge and rivets. You can peen over the rivets on a vise or use a big hammer on the backside as a dolly.
ETA Aluminum 3003 Continuous Hinge with Holes,
You will need a
Drill
1/8 Bit
1/8 x 3/16 Pop rivets
Pop riveter
Hacksaw
Some form of clamp to hold them for drilling.
ETA don't take this list as sarcasm it is just the simplest way I know of.
motoretro
USA
Thanks for the suggestion. I do have those tool items, I did notice the hinge is not available although local hardware may have them.
motoretro
USA
How about simple bent tabs through slots?
Or hog rings (or aluminum strips bent into hog rings).
I was trying to come up with something like this, played around with some cardboard tonight although nothing constructive yet.
PCustoms
VT
Of the alcohol burner? if so, I can provide one. The "U" shaped enclosure will be hinged at corners or attached with tabs, or whatever method I can come up with.
Of the box. Guess your still in the thinking stages?
PCustoms
VT
While those are pretty neat, the price is more than I care to spend, I figure (4) hinges total at $10.47 ea. plus shipping.
Cheap, light, strong (heatproof).
Pick 2
My other thought was to try to form the hinge out of the material and then add a pin, but I'm pretty sure 0.032 aluminum will need some annealing to make this work. I'll see if anything else comes to mind.
motoretro
USA
Pick 2
Well, I can purchase a enclosure for about the same amount of said hinges, that said, I'll have to go with strong and light:)
The idea of using part of the material the sides are made from is interesting, minimal and should be strong enough for it's intended purpose. Some type of slip fit might be workable. As far as annealing the material, the only source of heat I have is a propane torch.
PCustoms
VT
Should be plenty for that thin of stock.
You'll have to figure out how much of a "tab" to leave on each pice to roll into the barrel of the hinge. Trick will be to anneal just that portion.
I'd use a pice of stainless rod for the pin.
GeoBruin
Does it need to fold or can it just be 3 pieces that assemble and disassemble using a tab and slot method? If it only needs to be a prism shape when assembled and flat when disassembled, there's no need for a hinge.
motoretro
USA
I was thinking about that late last night. Just needs to either lay flat or fold flat. I think I'll grab some card stock and scissors and try a few shapes. It does have to be sturdy enough to support a filled Trangia burner and titanium coffee cup on top in assembled form. I'm going to hardware store today and look around, sometimes I get good ideas looking at odds and ends.
GeoBruin
I think you're on the right track with a cardboard mock-up. This is sort of what I was thinking. You could make it 3 or 4 sided, and even make more of them if you wanted a larger base for a pot. They would all stack with no added thickness like a hinge.
Edit: Rev 2 added with air hole on top side as well.
motoretro
USA
That's pretty much what I envisioned, perhaps a slightly different tang configuration. I have dimensions of the burner and need to work around that in order for everything to fit. That said, I have a 4"x10" of .032 aluminum piece, I cut this into (3) pieces, 3-5/16" wide x 4" tall. Strangely enough, I used a HD Xacto knife and blade and combo square to cut the pieces. This worked better than I thought although toasted a blade making the (2) cuts, took about 20-25 sweeps to get 90% of the way through and then snapped off like glass. Since the enclosure is basically a support and wind break, I think I'll put the cut out areas at the base. I'm going to keep it (3) sided in order to install and remove the burner easily.
*I did come across some neat stainless "L" brackets I could have used for a pivoting hinge although they would have prevented the whole thing from laying flat.
Monza Harry
Windsor ON
How about this? Two the same and one has to have a slot on the opposite sides for three sided [all 4 the same for a box]. Slips together and can lay flat in an envelope for travel. A hacksaw with a 18-24 pitch blade should cut the slot to fit your material. Cut all three at once, do the ones that are aligned, flip one and cut the next three slots all at once again. Harry 20231021_204939.jpg
