HLVP Paint Equipment
Spencer Was Here
Western Michigan
I'm looking for advice on which direction I should be looking for a HLVP system to paint just under 20 residential door slabs.
I'm no painter, nor do I aspire to be, but I own a couple of airless units I've put a few hours on. I assume they are not the ideal tool for painting door slabs and since they are kind of a pain in the *** to clean, I'm hoping a reasonably priced HLVP will both provide a better finish and be easier to clean.
These would all be new door slabs, either primed or primed and painted from the factory. I will need to paint or repaint them all to match the existing colors of the door frames/jambs/trims, which are not being replaced.
I'm assuming I will need to spend at least $500 on a decent HLVP system and I'm willing to spend upwards of $800, but with as little other use as this unit will likely see, I can't see spending more than that.
While a cordless unit would be great, unless it somehow accepted an 18-Volt Makita battery, I'm not looking to get into a new battery system. So, I am thinking it would be best to just get a 120-volt unit.
Any help would be appreciated.
todd_fuller
I think most pro painters are using fine finish airless setups, not HVLP. When you say HVLP, are you thinking a turbine + gun or compressor + gun?
metlmunchr
You CANNOT spray house paint thru a hvlp gun without over-thinning it to the point where it's not much more than colored water. The right tip for the airless plus a flow additive for the paint will give you a far better finish than any air type spray gun and you won't have to ruin the quality of the paint to get it to spray.
driz
Northern NY
More often than not all things considered it’s easier to just use a couple rollers and chase with a brush as you go. My overall favorite for all but huge walls is the little 6” long by 1” diameter. They fit nearly everywhere when you have a brush right there toget the deep recesses. Spraying is fun but setup is s PITA. Also you have to watch where the overspray blows ect....
