Hmmm ....
Ohio Andy
Columbus, Ohio
Frankly its a hole in wood, not a critical part of the International Space Station. Y'all need to relax a little.
Zim
Oh, and who has a caliper that measures in fractions? Get a chart. LOL
I bought one specifically for woodworking that shows fractions.
Ironically, I was trying to identify a particular postage stamp and one of the ways to attempt to differentiate it from another was by measuring the thickness of the paper. I bought one specifically measure that paper that's rather accurate.... I'm not sure if that one does fractions or not...
And the dimensions may not be critical for a space station, but if I need it to fit a particular size. Dowel and it doesn't fit. That's kind of a problem for me.
Ohio Andy
Columbus, Ohio
Zim
PCustoms
VT
That's not the correct but if you're looking to get a precise (wood) dowel fit
Wubicon
Zim
As my Dad was found of quoting "It's a fence. We're not building a piano. It's close enough."
zendriver
Indiana
Any taper at all?
Seems measuring the shaft would make more sense. It has to go through whatever is being drilled as well. :dunno:
gahrajmahal
Cincinnati, Ohio
Oldwizard1, I found when drilling deep holes in pressure treated wood I had better luck using a new twist drill than paddle bits or the type you show. I was attaching joists to deck posts, 6 x 6 and needed long bolts to go through and be tightish. When I used paddle type bits hey walked inside the post when it hit harder bands in the grain. Even thought the bolts would start in the holes they couldn’t follow the wavy path inside.
purplezr2
Central MN
I like to spin bits backward between the jaws to make sure that I don't measure the narrower portion behind the area that cuts.
Appears you are measuring it wrong. Did you measure the hole sizes it drills(don't see an answer to this). Did the bolt not fitting drive you to measuring the bit?
signcrafter
OP is bolting pressure treated wood together, not fine finish work. An auger bit isn't that right tool for finish carpentry detail work. Be like using a low tooth count blade for finish cuts instead of a fine tooth finish blade. Or 36 grot sandpaper to do a smooth finish. There is a right tool for every job.
dscheidt
Not much difference (except the tip) between this and a twist drill.
There's absolutely a difference. The snail forces a feed rate of whatever the thread pitch is. That's fine for blasting holes in studs, but it can be too fast for stuff that's harder to drill. If you look at auger bits used in braces, they have much finer threads.
I have three different thread pitches on different auger bits. My good RJ ones have a very fine threads. My coarse single spirals are much coarser. And some that seem in between might be double start, I’ve never counted them.
All with a tapered square tang for braces.
