Hoarding steel rod
elmer
Detroit
Hi my name is elmer and I'm a hoarder. I Hauled this steel rod home from Grand Rapids this morning. Won the bid $125-$156 out the door.
Theirs so much steel rod here my old F250 was doin a little squat.
Boogerman
aspen cove hill
That's great to get identified metal. If the bars in the crate aren't identified individually, I'd take a sharpie and mark them all so you don't get mixed up later. I hate turning mystery metal, have pretty much stopped doing that at all. If I don't know what it is, it's scrap.
E
elmer
Detroit
Some of them are marked, some have a tag, some marked with just a color. Would be nice if they were all tagged like this one
Fixr
SW VA
I believe I saw some TG&P stock there. That adds a few inches hg to the suckage.
E
elmer
Detroit
Where you looking for places to put it all when you came home ?
Did you unload it all by hand ?
About 1/3 was banded and I was able to lift it out with the end loader.
The rest had to be unloaded by hand.
Stacking it in several places in the barn.
NUTTSGT
Northern Central Ohio
I think that picture really puts the size into perspective of how big some of it actually is sitting on 4x4s.
E
elmer
Detroit
Definite suckage.... now, what are you going to make?
Roll up- roll on rotary table cart. Work in progress. Added these updated pics of the Rotary table cart.
LopezBart
Lopez Island, WA
Cool. In my garage in CA, I welded up a two level stand right behind the mill; if I ran the mill table all the way back and up or down to the right level, I could slide the Kurt vice or rotary table on/off the mill table. It does collect chips a bit, but it's worked pretty well, and helps prevent a hernia from moving the 10" rotary table. I'm looking forward to having much more room in our new shop when that gets finished. The top of the table is painted steel, so far, the paint is holding out.
Of course, do make some stops to keep that rotary table on the cart once you're wheeling it around.
E
elmer
Detroit
Some sort of stops yes I'm still working on that.
I think I might want to load- unload from Both ends, theirs probably gonna be room for the rotary table and a vise.
E
elmer
Detroit
Thanks Jswain. Lathe is a 1952 SB 13" with a lenze smvector VFD feeding a 1hp 3ph motor.
Definitely still in the learning stage of running the lathe.
dougf
Missouri
Nice score! I've been hitting the junk yard for round stock with varying levels of success. Cheap, but all the downsides of mystery metal.
LopezBart
Lopez Island, WA
I used to live fairly near an excellent scrap yard that offered both new and old metal; most of the things I've build have been from "scrap". Round stock is indeed where more mysteries are found; rectangular or square tubing is almost certainly 1018 or similar in my experience.
E
elmer
Detroit
What are you building?
I am Changing out this 7" multi-function device to a 12" mfd. The old screen is mounted on a 2x3x1/4x16 aluminum bracket and this 12"mfd is going to be mounted on the 4x4x1/4x16 aluminum angle.
