Tractor Supply has them
$819.99
★★★★★ 5 out of 5 stars. Read reviews.
5 out of 5 rating.5.0 4 Reviews
4 out of 4 (100%) reviewers recommend this product
Write a review . This action will open a modal dialog.
In Stock - Order Online Only
Quantity Add to Cart
Add To Wish List
SKU 1021970
Welder | Brand : Hobart | Process Type : MIG, Flux Core | Welding Amperage Range : 25-190 A | Input Voltage : 230 V | Weld Thickness : 24 ga. - 5/16 in./16 ga - 3/16 in. | Duty Cycle : 30% @ 130 A | Product Weight : 68 lb. More
Description Specifications More Information Reviews
Almost a $100.00 savings when welder and spool gun are purchased as a kit. This kit is only available for purchase online.
The Hobart Handler 190 package pairs the Handler 190 MIG welder with the SpoolRunner 100 spool gun - the only complete aluminum welding package in a small frame MIG unit - at a great price! The Handler 190 features a 7-position voltage switch and infinite wire feed speed control creating a welding arc that more perfectly matches metal thickness and wire diameter than any competitor in its class - less spatter, professional bead appearance, excellent penetration and minimal post-weld cleanup. Great for aluminum MIG welding with the Handler 190, the SpoolRunner 100 eliminates feeding problems associated with soft aluminum wire - it is also usable with mild or stainless steel welding wires. Comes in a rugged plastic storage case.
Includes: 10 ft SpoolRunner 100 spool gun with plastic case
Comfortable 10 ft HS100S4-10 MIG gun with liner
Built-in gas valve
Dual gauge regulator with gas hose
10 ft work cable with clamp
Power cord with plug
Extra .030 contact tips
Sample spool of .030 flux-cored welding wire
Spool shaft to accommodate 4 or 8 inch spools
Welds 24 gauge to 5/16 in. steel Welds 16 gauge to 3/16 in. aluminum
Operates off 230 volt input power 7 voltage settings for fine control and improved arc performance 25 to 190 output amperage duty cycle
30% at 130 amps durable feed head with quick-release drive roll lever
Easy accessibility to thread new wire dual groove, quick change drive roll
Self-resetting thermal overload system protection
Built-in contactor eases use and is an excellent safety feature which makes wire electrically ""cold"" when not welding
Made in the USA
Manufacturers limited warranty
Customers Also Viewed
$819 with the spool gun with it if you got one buy you i would get from them just in case you do have any problems you can just take it back, thats a nice welder i had the HH187 smooth welder has a soft arc start and a good wet out you will not be dissapointed with it
