Hobart Port A Flex welder wiring question
qmdv
I have had a Hobart Port a Flex DC welder with a MIG box that sits on top. It is 3 Phase and it has been run that way for about 30 plus years. Sold the ranch and have moved to where the shop has single phase.
Was told at purchase that all you have to do is drop the the delta leg and wire it 240 single phase and it will work fine but just will not be able to crank out as many amps as on 3 phase.
I cannot find the owners manual. Looked on line but have not been able to find one.
bdbecker
Iowa
Here's a link you might find handy:
https://www.hobartwelders.com/support/manuals-and-parts
Type in the serial number and it'll pull up your manual. You can also search by product name if you don't have your serial number. If you search by product name, just be aware that there may be multiple versions of your manual available depending on the production year.
welder57
Thanks bdbecker for the link. I need a manual for Hobart Fabricator. Big 240 welder I bought on line years ago. Welds great for it age. Have A Blessed Day!!!!
Q
qmdv
Tried that but no joy. My serial is 87WS13467
sberry
Brethren, Michigan
Some of it may be so obsolete they dont have it on there. I think it could be the case for some big ole gassers too. There was a spit and a aquisition, not sure exactly what happened in that window as far as he manuals went.
bdbecker
Iowa
That is disappointing. Might have to call the 800 number to see if someone can access it and email it to you. I've always has pretty good luck with Miller customer service (same parent company).
