A lot of times on forums I see fellers getting worked up over welders. Sorta like oil war threads. Well I've owned a few of them and it shouldn't have been that way. A GOOD welder is an investment. A bad welder is just a tool.
Several years back I was faced with a dilemma. Having owned 2 Hobarts, 2 Lincolns, and several HF models (all MIG or MIG converted), I knew that I wanted a MIG but I did NOT want to have to go through the garbage that I had gone through before. Both of the Lincolns failed at one point. WP100 the feed motor died which wasn't cheap but I had to have it for the job I was doing. I traded that welder for an SP130 I believe it was, it was brand new but the owner didn't have 220 service.....which was a little more powerful. The circuit board died in less than a year. Since I didn't buy it at the local welders supply house, they wouldn't give me any help with it other than tell me that the board was dead and that it was $400+ to replace it. That was similar experience I had with all of them. HF welders, if they die, you replace them in their entirety, period. If out of "warranty", YOU get to replace it. If IN warranty, locally there's some hoops to jump through to get 'em to replace it. I certainly didn't want to have to deal with those issues after I moved out to the sticks, where it's an hour drive to anywhere. So in '13 I looked around some more.
What I found was that Hobart 210 and Miller 211 are almost the same welder, with the differences being that the Miller has a little better circuit board, a little better quality transformer assembly, and the feed motor has metal gears in the miller, and plastic in the Hobart. I didn't want another Lincoln based on two failed units that should not have based on the low hour usage. I priced the Hobart 210 at the local TSC store, right at $900. BUT I also found a smoking deal on the Millermatic 211, comes with the welder, leads, el cheapo helmet, and a FREE spoolgun, $1100 and then a $200 mail in rebate, so it came out the same cost as the Hobart. You bet I bought it. It's hotter than 210 amps I believe. MVP. So far I love it. We have a 210 Hobart at work and the Miller seems to weld a little hotter, the feed is smoother, the arc is smoother, drive rollers are of better quality, among many other things.
