top drive
My dremel went up in flames using it with a burr to clean up a joint for welding in an enclosed space- occasionally i use it to do cuts with small disks in tight spaces
Do i buy another dremel or similar or should i just go and get something with a bit of meat behind it like a die grinder.
Or is there something between a dremel ( which frankly was **** anyway) and a die grinder as the die grinder does seem a bit wild and most only seem to have one speed at 20k rpm..... The dremels multi speed was good.
Any ideas
Cheers
Any ideas
Cheers
