Hoist??
clawman
Do you have one? Is it free standing or perm. mounted?
In my new build I'm thinking of mounting I-beams on the trusses and a crossing I-beam to hang the hoist on. Frankly I do not know how much I would use it but there have been times I'd like to lift an outboard off the boat or ?? Is this overkill vs a portable gantry on wheels?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Man, I'd love to have a hoist in my garage. I get so damned pissed when I have to get the wife or neighbor to help me lift something up or out of the truck. Normally I have to use my tractor, but it's tucked away in the corner for the winter with a bunch of stuff packed in behind it. :mad:
revkev6
my uncle has one in his shop. combined with a an adjustable engine lift point it makes things almost too easy. we swapped motors in a nicely painted 40 ford two years ago in about 20 minutes. no scratches no rushing. not even any SWEARING!
Smiliesafari
Orlando, Florida
I have an I-beam over each bay with a 500lb capacity hoist on a trolly. My garage is a metal building with 2 1/2" tube welded trusses. I welded the I-beams right to the bottom of the trusses. At my age (72) I don't lift much of anything. I can't imagine not having these tools. You will never regret it.
rlitman
Long Island
Is the roof designed for the extra load?
Mine is not, but the heaviest load I have to lift is under 600lbs. And that is considerably smaller than the designed snow load of the roof. More importantly, it is also way smaller than the snow load for just the area of the roof that I have the load spread over.
No, I would not expect to be able to pull that much from a single rafter, or even two. That's just nuts.
Anyway, for me, the typical lift is 50-100 lbs of stuff going into my loft.
Twice a year I lift the snowblower. That's about 250 lbs.
freudianfloyd
Nowhere
I just installed one a few weeks ago. I have it posted somewhere, but no reason not to post it again.
[/URL][/IMG]
[/URL][/IMG]
OccupantRJ
Eastern North Carolina
Hopefully mine is now. No snow load here to speak of, maybe an inch every few years. I put the beam up between two trusses, running parallel to them, with a support post on each end. The two trusses were highly reinforced by adding twice the W bracing as original, then the two trusses were tied together and cross braced to provide what I would describe as a wooden bridge trusswork.
The two lower chords were also doubled up in height, and a plywood layer was added to tie the two chords together. After that, a plywood floor was added on top of the doubled chords to provide a tray for the beam to recess up into to provide more lifting headroom.
An additional layer of 2x6 collar ties was added at mid truss levels onto the triangle of the two trusses and the W members to attach the 9 beam hanger rods to. All these connections were bolted together.
It will pick up 800 lbs without a sweat, although I would not be leery of picking up my Bridgeport by adding a temporary stiff knee under the beam's center. A 4x4 on top of a hydraulic bottle jack works well for this.
I have about $475 in my beam setup by buying the beam steel new. The posts are 3" schedule 40 pipe from recycled satellite dish mounts, and a lot of the wood was scavenged free from work from various oak and pine shipping crates.
bad_idea
Pasquotank, NC
I have an i beam against the ceiling of my 14x20 garage 8' off the back wall. It is supported by post in the wall cavity. It is attached to the top plate of the walls on each side.
Very handy. I have used it to lift things out of the truck. Pulled an engine with it. Built my weld table in the garage and used a couple chain falls on the beam to flip the table around for welding (be damned if I'm welding overhead).
If I had a bigger space, a bridge crane would be ideal. Costly though. Rolling gantry would be the next best.
slip knot
Texas gulf coast
I'm looking at a gantry crane just for unloading the truck. I work with a lot of small welders and gensets. would really help out to have it in the shop. As it is I have to either get the engine hoist out or use the FEL on the big tractor. Both are a real PITA.
J king
Ne oh
I built one from scratch. I had plans to build it when I built my addition. Had to bump up ceiling for a little more height.it isn't a must have but damn near.lol..hard to lift rotary table or a 4 ft shaft into machines by hand.
Forever Fixin
MN
I have an 8' jib crane. mounted to the floor and ceiling rotates about 270 degrees, has a chain hoist on it. Doesn't get used much, but very handy when needed.
bob15
Northeasten, CT
Go with a cherry picker or a large tree branch and a couple straps. Even better, buy a farm tractor with a loader on it.
One issue with overhead hoist on beams is head room. How high is it off the ground? A chain fall and trolley set-up will eat up several feet of head space very quickly.....
mechanic217
I was going to install one when I built the shop 30 yrs ago but went with an a frame gantry just outside the main door and a big and small cherry picker one each, the big one never leaves, the small one can be broken down in a few minutes and taken anywhere, this has worked for me .
sberry
Brethren, Michigan
I have a gantry, forklift and the cherry picker is the one most used.
