holding mandrel pipe together for tacking
that-guy
NoVA
so, working on stainless exhaust and aluminum turbo piping, i often come across issues with getting the pipes to stay where i want them so i can tack them together. i use masking tape most of the time, but sometimes if the shop is really hot, the tape will not stick to the material. what have some of you used in the past that has worked the best???
superspec
WM louisiana
I use the vise grip type for tubing. works great for most any size i use other than 3" and thats fixed with the bigger pair.
phill u7c
Cambridge, UK
If i can i use a bit of tube the ID of the tube im trying to weld's OD, then cut that piese of tube in half, and clamp that to the tube i want to weld, maybe via a hose clip or 2. That then acts as a saddle to rest the tube to be welded. i know it sounds a bit half ased but it works for me.
T
that-guy
NoVA
well, i have used silicone couplers before by cutting a simple window in them to allow for the tack. i guess i should reiterate my question by asking how it is that people hold two pipes together that need to be tacked somewhere on the bend?
metal tech
I use some flat stock on each side of the tube clamping each end of a bend using kinda what fits to get it done, like splinting a broken leg.
Guster
Auckland, New Zealand
2 pieces of angle iron and 2 of the chain type vise grips
bob
Ditto.
I keep a few stainless angle offcuts in various sizes for just this purpose. Still have two pieces of 150mm angle I used to align some 300mm tube I hade to do. Just make sure there is no burs on the ends of the angle sections as they can throw out the alignment.
HavATampa
Exhaust welding band clamps can be purchased or easily made. Summit has different sizes.
http://www.summitracing.com/search/...Welding Clamp&SortBy=None&SortOrder=Ascending
T
that-guy
NoVA
this rendering better illustrates what i am asking...these are two pieces of tangent 90* pipe butted up to one another with no straight and cocked at a weird angle...if you didn't have the choice of using masking tape, how would you do it???
my58
Ventura County California
I know you will think I am crazy, however for just tacking I have a large sandbox that I submerge the 2 pieces into. The sand holds the pipes exactly how you want and allows you to easily tack it.
This technique of holding things was shown to me over 40 years ago at the old Brooklyn shipyard (Navy Yard) by a guy 90 years old at the time. It has never failed me.
phill u7c
Cambridge, UK
That is GENIUS, I will defiantly steal that idea, thanks for sharing
T
that-guy
NoVA
that is a simple yet inovative idea...thank you very much for sharing (heads to beach with a shovel and pale) :rocker:
superspec
WM louisiana
+1 thanks!
Jere
I clamp most pipe in the HF rotating vise, and lay the other half on the table. The vise is mounted on the side of the table to help with this. The other thing I do is tack one end of some scrap rod/bed frame angle to the steel table top, the other tacks to U bolt style exhaust clamps. The clamps hold the pipe and this works well as a simple jig if I am making duplicates.
ng8264723
Oakham MA
I have used blue tape. I tape it in place and then use a utility knife to remove one section at a time
ADSR
we need a pic or demo of this system! !!!!
