Hole cleaning pump
hemdale
France
Hi guys,
I'm about to drill several deep holes and I'll be using some chemical fasteners.
I know it is highly recommended to clean all remaining dust inside the hole.
The vacuum isn't enough and I wondered if you had any cleaning pump to recommand ?
Just saw that:
http://shop.grfasteners.com/Fischer-ABG-Hole-Cleaning-Pump
Or maybe something simpler like this:
Let's see what the others are using. :thumbup:
signcrafter
Go to the hardware store and get a tapered rubber plug that will fit the end of your shop vac. Drill a hole in the middle of the plug and use a two sided barbed fitting to stick in the plug and then attach a clear plastic hose to the other side of the barbed fitting. Then just stick the hose in the hole.
H
hemdale
France
Thanks guys, i'll go with the tapered rubber plug option. I'll I've it a try, thanks a lot for the tip !
