Greetings MM!!
Welcome to the world of vise vice!
To get your "Main Nut" out....
1. Remove your "Dynamic Jaw" from the vise....usually you just turn the handle and the jaw will run itself out and the "Lead Screw" will disengage from the "Main Nut".
2. Take the "Main Body"...the one that has the base attached to it....take off the swivel base lock down nuts...maybe one or two depending....just unscrew them off the bolts
3. Turn the Main Body over and on the bottom of the swivel base in the middle you should see a Big nut or bolt in the middle. Unscrew this bolt out and separate the swivel base from the Main Body. Some vises won't have a center bolt (Wilton Bullets don't have one) so do what you need to do.
4. On the Main Body bottom.....off center you should see a small hole....it will have a pin in it sticking up/away from the bottom. This pin sticks up behind the Main Nut and is what keeps you from sliding the main nut backwards in its dovetail and out of the vise.
View media item 8893Take a tapered punch and hit the pin on the bottom....you are going to knock it out from the bottom towards the top (where the nut is at). It will only be sticking in about 1/2" or so. The photo shows the pin removed and where the punch should go.
Once the pin is out, you can attempt to slide the Main Nut backwards in the dovetail and out of the vise. Many times (most) , it will have enough crud that it won't slide. Just use some carb cleaner....solvent....air gun...to remove the crud. Then take a wooden dowel or a PVC pipe (like 1/2" ID or 3/4" ID) and hit the Main Nut from the front to move it backwards. Hit is as LOW as you can. Use a brass drift but try NOT to use a steel tool as that nut is expensive and will crack if you wail on it with hard steel.
Good Luck and keep us posted!
Craig
