Half you noticed this anywhere else in the garage or basement?Depending on what kind of soil they backfilled with and how it and the stone were compacted, I'd say it's very likely that the base and sub-base have settled. If it settles enough, that corner of the slab will crack and drop. The good news is that this is a repairable problem.
1. Least work is to have a slab-jacking or mud-jacking (different names for the same type of contractor - look in the yellow pages for a foundation repair company) company come in and fill the void from above. They would drill a couple of 1" holes and pump a slurry of water, sand, and cement into the holes. Once it dries, the slurry becomes a grout that supports the slab.
2. Remove the suspect slab without undermining the adjacent concrete. Make sure the soil and gravel are well compacted. Replace material including the vapor barrier and reinforcing mesh. Use 1/2" diameter x 12" rebar dowels to connect the new concrete to the old concrete. Let it cure and you're good to go.
I've seen method #1 used to fill a void 2" deep x 6' wide x 60' long without problems. My parents also had their driveway repaired that way. I want to say it was about $500 to do half of a 22' wide driveway 25' long about 7 or 8 years ago.
The other thing that I'll mention is the new home warranty that came with the home. In some states, the builder has to supply a structural warranty that is longer than the full warranty on the home. Example: Indiana requires a 2 year comprehensive warranty, 4 year roof warranty, and a 10 year structural warranty. If I was in your shoes at my house, my first call would be to my builder.
