Homade Shop Press Tooling
coolguy
Anyone have pictures of Home made shop press tooling?Looking for Jig's,
fixture's and maybe press plate's.Thank's so very much for you time and talent.I will not "Bump"this thread to the top to keep it going.If it fail's it fail's !!!!
plinker
Northern Wi
No pic's but where I work there's several different jigs, some I'm not sure what they are for though.
One is a V-block and and edge for bending steel in to angles. I'll look saturday and post back.
mtnkrake
This is all I've got. Swag off-road press break and a few little jigs.
ptschram
Churubusco, IN
Mine. The lower die can be interchanged with a piece of angle or a piece of tube.
I have all manner of tooling for pressing suspension bushings in and out. Makes the job easy, fast and safe.
DandDMachine
Bloomington, MN
Not sure of what kind of work you will be doing but I run a machine shop and we press alot of front wheel drive bearings and bushings etc.. I find the best pieces for that are old bearing shells, both inner and outer races. We save what we take out and keep an assortment of sizes handy. Those and a bearing seperator or clam shell does 99% of what I do. They are basically free and do the job perfectly. Just sure to wear your safety glasses, since they are so hard they are also brittle. I have a 50 ton Dake press and over the last 18 years I have broken 3 races. The broken parts can be sharp when they go flying. Old wristpins and beat up sockets also work well.
lotsoftools
Inland Empire
I have a couple of shafts from electric motors, I think. They are about 3/8" x 5" and 5/8" x 6". I use them when I need to press something small in diameter.
Buckgnarly
VT
I also save bearings, races, shafts, etc. Swag is a great place to buy stuff if you don't want to DIY.
cranejon
BE SAFE A press is a very under rated danger. I worked in a shop where a piece flew out of the press and hit another worker in the head...Hearing stories of brittle (hardened) races shatter in the press scares me.
jxxxoxxxe
anyone ever used a press like an ironworker? I wonder if it be possible....20 ton probably wouldnt be enough...I'd love to be able to shear some thicker stuff...
C
coolguy
When you get to be 67 and lose a little of your mind you make a full custom
press like this 20 ton !!!!!!!! LOL
Keep
Oshawa, Ontario
Very interested in this. Most of mine consist of scraps of angle iron and 1/2 plate I grinded into a 45.
mikeatrpi
Home
Hey cool-guy, I noticed your press is mounted on wheels. How do you like that? I could use some wheels on mine for storage but am concerned about stability during use.
Jbullfrog
Avoca, Iowa
My press has a 1" bore, so I have made a few inserts for it with 1"bolts and a nut. One of them is a pin punch holder and another is a bushing driver shaft to hold all of my bushing driver discs.
BobsurUncle
Tracy, Ca.
That brake deal is pretty cool. I'll have to try that. Since my press has in the past been mainly used for "gunsmithing", my homemade jig is a stack of pennies super glued together.
mtkst19
blitzburgh pa
i have some scrap pieces of rigid pipe--range from 2 inch to 5 inch. i will use the scrap pipe as spacers as well as holding jigs for when i press in/out wheel bearings on a spindle. also use old sockets, actual press plates, and believe it or not vw 5 speed "vibration" blocks.
On 93-99 vw golf jetta 5 speeds, they put a thick heavy block on the rear cross member for what i suppose was a vibration dampener. these are awesome for stacking to raise a piece or to use as a press plate. here is a pic of where it is located at on the cross member. it is the block w. 2 bolts going through it
89GLH
Westminster, MD
If that brace you're referring to is anything like the old Dodge L bodies, that was for a bobble strut. You could use it to add preload, so the engines don't rock back so far under load.
MitchL
Hey coolguy that is a nice looking press, Did you use the press to make the louvres for the press on the laterals? (Use the tool to make the tool) would love to see the tooling set up for that. :thumbup:
sk farmer
nd
full custom? it looks like a harbor freight press with artificial louvers, a coat of paint and some pinstripes on it. :dunno:
kyrbz
midwest US
The anvil on my 12T HF press was welded on crooked and the crossmember it was welded to was a piece of brake formed sheet metal that seemed kinda wimpy. I remade that part with some 1/4" wall channel and also made it so I can change the anvils. I also got tired of pumping the jack and changed it out for a pneumatic/hydraulic one. I also have mine on wheels and have never felt like there was an issue with tipping.
