So I'm hoping for maybe a little insight here, any help is appriciated!
Last week, I went down the basement and found a small puddle of water on the floor, maybe a 3' square area. It looked as if it had come from the bottom of my furnace. I cleaned it up, and turned the a/c on for the next 2 hours trying to find a leak, could not find anything. Ran the a/c as needed for the rest of the week, no issues.
This morning I go back into the basement and there is a serious puddle of water. I mopped it up, and was close to 3-4 gallons. I turned the a/c off, took the pump off the side off, and took the side panels off the furnace. The bottom one, where the circulating fan is, has a good big of water sitting in the bottom, and leaks out of the corner. Water seemed to be coming from above, so I took that panel off and looked up there. The condenser? (I think) appeared to have water dripping off of it. Which in turn was dripping down into the fan compartment, then put into my floor.
Am I pretty much screwed here? A/c seems to operate as it should, cools House to 72-73 which I keep it set at. Is the condenser sweating for some reason? This will be the third summer I have been in this house, and it had been great since I moved in. Original unit, it is about 13 years old.
Any help here?
Any help here?
