79loserbluebu
- Joined
- Feb 26, 2013
- Messages
- 8
I know this subject has been beaten to death on this forum. But I have a question about the nylon kits that are being sold.
I'm not sure how I would like to run mine yet, so I was planning on buying a master kit, laying it all out and then adding any pieces I would like.
I have a Husky 80 gallon 5hp compressor, with a 3/8 outlet. So my plan is to run a 3/8 pipe to a regulator and then a flex line to the nylon line.
Now for the plumbing bit. It says that if I am using more than 100', to go up one more size than the compressor outlet. This is only going to be for my home garage, meaning at most me and my dad will be using an impact or air ratchet on each side of the car, but we won't be continuously going at the same time. Is an additional size needed?
The reason I ask is because the Rapid air kit is only 1/2od, meaning the hose is only 3/8 od and it uses nice simple plastic air fittings. The next step up would be compression fittings and also more expensive.
If anyone has any real world experience with any of these please let me know. I like the system because it's simple enough that I can do it by myself and move it around if I get tired of how it's laid out.
I don't plan on painting color on any vehicles, maybe just priming them so I don't know if that factors in. Also I just purchased the larger blast cabinet from HF to use.
