Kielbasavw
So I'm trying to anodize a part. And having some issues.
I have a bucket mixed with a gallon distilled water and 25oz sulfuric acid I have my part hanging with 3/32 stainless wire. I have a piece 3x2 aluminum square tube for the negative.
Here is my problem
I've tried several different power supplies. 2 battery chargers and a 12v battery. They all give too much amps. I can set my charger to 12v 2amp and the machine reads 50 amps! Things get hot and acid solution turns yellow.
I currently have a small 12v charger that charges at 4 amps. It will peg the dial for a couple seconds and shut off for about 5-10 seconds and turn itself back on.
If I hook that same charger up to a battery it will read a constant 4 amps.
What gives?
Here is my problem
What gives?
