If you have great experience with cinder block/cmu’s that’s great and wish you well with the choice. As I said, my opinion is that cmu is a poor choice for a buried foundation given other options today. Call it cinder block vs cmu and you fully understand; similar to the water heater vs hot water heater nonsense that some posters harp on (and the 110/220 VAC vs 120/240 VAC comments/posters).
Getting the vertical steel reinforcement placed properly in the cells, horizontal reinforcement wires in the bed joints, getting the cells properly filled and vibrated without cold joints, all are weak points prone with error. Very few are done properly, again in my opinion. If your guy is great and on top of his game, then proceed and hope that a wet basement does not occur. Not saying poured foundations are leak free; I’ve had my share.
Can a 5-6 man block crew lay a complete 9’ tall buried foundation turnkey in 2-3 days with reinforcement and full inspections and zero cold joints in the cells? Doubt it. Poured walls in my area we stand panels one day with steel placement , inspect the 2nd day then proceed to pour, strip the 3rd. During spring and summer we stand, inspect, and pour in one day due to longer day light hours. This with 3500-10000 sqft homes on 2 floors not counting basement.
If the nearest concrete plant is 15 counties away, then yes you are probably SOL with a poured foundation. Thus cmu is your only choice with proper attention required unless you bring in precast walls and a crane to set them (OP mentioned Superior Walls which I believe is a precast outfit).
Wish you the best. Remember with opinions, you get what you pay for.
