Hey guys,
My small 900 sq. ft. home is heated with a BROAN 10KW electric furnace that was put in around the year 2008. It's very basic with no electronic circuit board or 2 stage blower like modern electric furnaces have.
I've had a trouble with heat output for the longest time, and I'm really starting to notice it with the temperatures we've been experiencing for the last couple of days (-35C). I've had trouble keeping my home, which is insulated to R19.5, even 19C.
I believe my return air duct is undersized. The reason I think this is because when I've removed the front panel to inspect the furnace (while it's running), giving the blower maximum air, the temperature at the register jumps from approximately 22C to 30C according to my temp gun... I know it's not an accurate way to read temperature in this case, but it gives me a baseline for improvement.
My return air duct is tin and measures 6x14, and then necks down to 4x12 as it runs along the underside of my floor joists. Seems awful small.
What do you guys think?
Thanks,
Derek
Thanks,
Derek
