fleming23
I will openly admit, I am just getting started on this process and will absolutely do as much research as possible. What would you do, knowing what you know now, for a new home and/or garage (built from the ground up) as far as cameras/dvr, or other security goes? I have a few months before we should even begin clearing our new lot but only get one shot at doing this right the first time so I want to be well informed.
In our current home I have been utilizing the Ring PRO door bell and flood light camera but only have those as they were the most convenient option given my existing wiring. We use simplisafe for our security needs and other than the keypad looking about 25 years old, I have been reasonably happy with the performance of that system as well. For camera prewire, I am thinking each corner (or area where I might want a camera, porch, deck, basement, etc.) of the house should have a 120v outlet and run of cat5/6. I can probably limit the exterior to opposite/diagonal corners (as appropriate), front porch, rear deck so as to not go overboard on extra outlets, if these are even the best approach. Most things are transmitting wireless, which is fine (EERO has our wifi coverage pretty well sorted), but still require a power source, thus the standard outlet at each camera location. What I have not decided is what actual hardware to use. I'm leaning toward a non-subscription based DVR platform but do enjoy being able to live feed the Ring cameras when someone pulls in the drive or leave a package at the front door.
Any tips, pointers, or useful links would be much appreciated as I know I have some reading to do.
