Home Interior HVAC - Frame to Foundation Gaps
goodysgotacuda
DFW
I think I know the answer to this one, but I will give it a shot.
Our home has several very cold areas in the Winter which are being driven from underneath the baseboards. The carpet against the wall is very cold and I suspect the house frame is not properly sealed to the foundation.
Without tearing everything up, is there anything that I can apply in homes to slow down the air leak?
If not, I assume either the baseboards need to come up, or the siding off of the house to properly address this?
cajunfirehawk
Ms Gulf Coast
Our house on the MS Gulfcoast has the same issue, a few things we used;
  • clear silicone caulk if you can get to the gap
  • those spray cans of foam sealant
  • round foam weather strip sold at hardware stores, jam up under your sheathing/siding on the outside wall to fill the void so air cant get into those gaps
Good Luck!
TractorJeff
Elkhorn, WI
LOL! I have the same problem! Most of you know I live in a barn that was converted in the mid 70's. I opened the border wall a couple of weeks ago while changing doors and found a poorly insulated concrete knee wall where the breeze blows in between the wood and the concrete.
My Spring/Summer plan is to remove the lower exterior sheeting and use spray foam to seal the gaps. I am toying with removing the interior border wall to have it spray foam sealed which would cover the concrete knee wall better also. Though I am partial to believing this may also open a realm of more poorly done work that I would rather not know about!
