Hi guys, I restored a bench grinder but the guides to support the work were incomplete so I got to thinking how to make some that would make it possible to sharpen hand plane blades and similar things that I’ve always had trouble keeping a straight line on. I wound up making this full width track set up with a sliding sled.
The track extends 5” past the wheels on both sides and tilts up and down so it’s deck angle aims from below center of the wheel, past center, to up over the top of the wheel so your angle of grind is adjustable. It swings upside down to get it out of the way too.
The sled is a 5”x7” plate with 3 - 1/2” square bars tacked onto the bottom so it contacts the track on the outer edges and the inner surface between the 2 rails. There is a 1 1/2” overhang on one edge of the sled so it can be turned around to reach close to the wheel when the track is tilted up. It is tapped for 1/4” hold down fasteners. The big hole in the center (2nd photo) is for a rotator plate I've added.
Here is a hand plane blade I put an edge on with this system. I didn’t grind out the old rounded corners at the shoulder of the edge, just the edge itself but I’m pretty happy with it so far. With the work clamped down you can slide the sled right off to dip the blade to cool it every 4 or 5 passes. I likely won’t be clamping too much to the sled, just hand holding it on there.
PS: by the way those 2 hold down bars with all the holes in them are just what was available and will be replaced. They aren’t needed most times. They are from some unknown machinist type devise so if anyone knows what they are please chime in.
In hind sight I should have made the parallel tracks to fit IN-BETWEEN the grinder mount arms so I could have welded a solid tube between the 2 mounts. The way it fits on the out-side of the arms allows for some distortion when tightening the tension to lock it’s angle. This tension is enough to bind the sled in the track. I have to keep it a little loose. Although it’s still quite usable I can’t lock it real tight so I’ll probably change that in the future.
