Home mechanic must haves
webbs2jzgte
Hey guys. I'm currently working on a lot of projects on a tight budget. (Aren't we all). I have had an issue where someone broke into my garage and took a bunch of random stuff. Since than I have moved and currently working out of a one car garage while in of legend.
My question is I know some kids who are looking to get into cars and I want to help them by giving them a must have tool/resource list. Hoping you all can chime in. This will be aimed at everyday DIY projects on tars as well as around the house so here's a basic list we can expand on hopefully.
-ratchets (1/4 , 3/8, 1/2" drives)
-sockets
-big screw driver collection
-rubber mallet
-everyday hammer
- pliers ( general, needle nose, channel locks, )
-vise grips
-corded or cordless drill with standard bits
-jack
-jack stands
-wooden service ramps
-fluid drain containers
Any others please feel free to comment. I want to get others interested in becoming mechanically inclined and hope to eventually put together small tool kits to give to some kids who may need help with that.
General Geoff
Allentown, Pennsylvania
I would add a 3lb drilling or engineer's hammer to that list. Sometimes you just need a BFH to get that stubborn control arm off. And make sure that "everyday hammer" is a ball pein; claw hammers have no place in auto repair!
Set of prybars would be ideal.
Also, a full set of combo wrenches in 6mm up to at least 24mm (and corresponding standard sizes if they work on older cars). Skip the ratcheting box end wrenches for starters, you want the thinnest box ends you can get to slip into those real tight spaces.
Jvvmusme
Bogota, Colombia
Moto tool
Grinder
Entension bars in 1/4 3/8. And. 1/2
Ratchet wrenches
Oiler
Good light
Patience
Good screwdrivers
Cutting devices
Heavymetalmechanic
Calgary, Alberta, Canada
All that plus: safety glasses and earplugs!
Chemical ice pack, eyewash bottle, basic first aid kit, box of nitril gloves, dust mask/respirator, case of cheap 500ml water bottles.
6" c-clamp, propane torch, heavy gloves, 12-18" tapered punch/drift, 1"x10' ratchet strap, roll of mechanics/baler/utility wire, brake-klean, paper towel.
When I was renting a basement suite I had all the bare essentials in two big Rubbermaid totes and a large 2 handle portable tool box, so it is possible to have enough to manage to deal with most repairs.
The eyewash is an absolute must have, when you get brakeklean behind your glasses you can not even think, let alone find your way to a sink.
If you are on a budget ...
Skip all of the 1/2" drive sockets, ratchets, etc. EXCEPT for a set of flip lug nut sockets and a 1/2" breaker bar.
Sparkyjack
Westminster MD
Eye wash station - any guidance on where I can buy one?
I've been very lucky for many years and realize I should deal with this.
I'm looking for the bottles with the top that you press against your eye and squeeze the bottle.
Jack
Leaflessshadetree
Don't ask.
My list of basics:
Combination wrenches (or box and open end wrenches)
Screw Drivers
Pliers (needle nose, vice grips)
Large adjustable wrench (Smaller sizes may also be handy).
Allen and Torx wrenches (or bits)
Jack Stands (most vehicles come with a jack).
Large Ball peen hammer
1/4 and 3/8 sockets and ratchets.
NewEdgePerf
Test light
Jumper leads (for testing/by-passing)
remote starter switch (when working by yourself)
Wire strippers and "good" crimpers.
I hope this helps.
Tony D
iadubber
Farley, IA
How about a decent stacked tool chest? I've been impressed with the quality of my Homak set from northern tool.
IlliniJeeper
Illinois
No one has mentioned a creeper or a mechanic's seat yet? They're indispensable in my garage and they'll save your back and knees a lot of pain in the following days.
Hobbit
Bama
Saw Horses & a 2' X 4' x 3/4" sheet of plywood for portable work table.
Portable Air Compressor w/small tank
Speed square
Seal Puller
Good 35' steel tape
4' wrecking bar, Heavy 20' chain, Recip. saw (use to make good money in high school pulling down & hauling off old sheds & out buildings with these three tools.
bczygan
DETROIT! Arsenal of Scrappers
Torx
Electric tape and connectors
Wire
Extra fuses
Flashlight and extra batteries
Magnetic pickup extendable tool and telescoping mirror
Work light - corded
Extension cord - 100' HD
Big piece of cardboard for lying on the ground under the car.
Battery post cleaner
Distilled water
Shop towels or rags
Spare auto bulbs
Chunks of 2x4 and 4x4 to adjust the jack
Shop vac
Auto cleaning and detailing supplies and buckets
Water hose
Tire gauge
Extra fluids oil, coolant, PS, brake and WS washer.
Propane torch
Soldering gun and solder
1/2, 3/8 and 1/4" torque wrenches
Oil drain pan
A bunch of other stuff you won't realize you need, until late Sunday evening with the car taken apart.
Syberia
Perris, CA
Magnetic parts tray
Impact wrench (even the cheapo Harbor Freight electric one is better than sitting there in frustration after rounding off a bolt you couldn't get out)
Sent from my Tricorder using Tapatalk
Tarheelgarage
NC
All you need is a good credit card; leave the work to the pros so you don't hurt yourself.....:rocker:
Lassen Forge
A good roll around work chest, with the tools inside and a tabletop on the top. Take the most used tools to the job, not have to run allover the shop over and over to do a simple job...
And a good set of swivel casters under it, that will handle some weight and still roll well.
Did someone mention a big compressor and air tools. Yep, someone did. Best investment you can make.
Sask dude
Saskatoon Saskatchewan
6 point impact sockets ! I won't buy 12 point or thin wall chrome again. To me there's no point as you can't use thin wall with a gun and 12 point is more likely to break or strip due to less contact area.
Plus you only need one set and save money and storage.
metalhead140
NSW, Australia
Gee! Starting out, I bought a reasonable Stanley 3/8 drive ratchet and socket set, followed shortly after by a big (very) cheap spanner set and a set of screwdrivers. That, along with a couple of jack stands, enabled me to do a hell of a lot of work, including suspension rebuilds and engine and gearbox replacements (though I did borrow a chain block for the engine replacement). Sure, get a digital multimeter when you need one, and other bits and pieces (some pliers and cutters, or vice grips) as you go, but realistically for working on cars you can do the vast majority of jobs with these few tools. When starting out you don't need all those extras, they are just to make life easier. I didn't own a trolley jack for the first 2-3 years working on cars, as cars generally come with a jack! Do none of you remember starting off on a tight budget and no tools, or have none of you been in that situation? If you want to work on house stuff, add a drill and a saw and there's not much you can't do! Other tools make life easier, but to me those are the essentials.
nicksnothereman
In the Mojave
-sockets
-rubber mallet
-everyday hammer
-vise grips
-jack
-jack stands
When you're on a budget...a lot of this stuff shouldn't be in your garage. I mean 1/4"?:bounce: Come on man. I'm still trying to find an excuse to buy better 1/4" stuff and I haven't found it.:sad:
But...different strokes for different folks. I don't know if you can buy wood service ramps but I like the idea. It can be hard to plan projects tool wise because you won't know what you need until you start doing it...you can load up on incidentals ("maybe I need this") but the way it usually works is even that stuff won't be what you need. Been there too many times.
mbret2004
repair manuals/internet access to same
flexible magnet
flexible "pick-up" tool
hand impact
flare nut wrenches (brake lines)
fender covers
crows feet
bleeder kit (mity vac)
wobble extensions
