sadiesgarage
- Joined
- Dec 22, 2012
- Messages
- 2
I recently hired a California contract to install a polyaspartic coating in my garage. When he bid the job I made him aware of a very large oil leak which he said he could address with industrial solvents. His company then started work but in the first attempt only ground the floor and put on a "modified urethane primer". The primer was repelled in the oil area. The contractor said that he was sorry that his guys tried to cut corners. He then made two attempts to grind and clean the oil but the primer is still reacting. The contractor is demanding more money and said it could take several more attempt similar to a repair shop he had done. When I shared my concern about his contaminate removal process he suggested we stop work, wait a few months to see if the primer delaminates but demands I give him half payment or he will place a lien on my house. He says he is entitled to both more money and partial payment under some general state law(not in the contract i signed). He also said there is only a 40% chance the top coat will adhere.
I sent a picture to the manufacturer who said the the primer is "separating" but not yet "delaminating". They also said that there product isn't designed for oil containment.
Here's my question's.
Can a have a second contractor salvage some of the job so that I might give the first contractor something for his effort should we not come to an agreement?
Can you put an epoxy top coat over a "modified urethane primer"? the manufacturers website says the primer is designed for use with "polyurea" top coats?
Thanks in advance!
Thanks in advance!
