Home shop fans
The Frisco Kid
Central Texas
Didn't see any posts in the search, but I'm sure that you guys have done some good research... who has a shop fan or custom fan setup in their garage?
I've got an L shaped tandem garage in Texas, and it's HOT in there!! I need to get some air moving in here!
pmiranda
Austin, TX
I've got an L-shaped tandem as well... I was kinda thinking of a ceiling fan since the 3rd bay isn't well suited for a lift although I get by OK with an old floor fan like this:
Carbine
Tyler, Texas
I installed a ceiling fan in my 2-car garage. It makes a difference, except for now cause it's in the 100's
August in Texas is brutal. The only way I can get anything done is early in the morning, or at night.
jkherd
Southwest Missouri
I mounted two in my shop, it does take the edge off the heat.
DHCrocks
Hawaii
I run a couple of these guys.
http://www.samsclub.com/sams/pivoting-utlity-fan/prod8670795.ip?navAction=
I put them on top of the upper cabinets on the far side pointing straight out the garage door. they sure do move a lot of air, not the quietest but very effective. Since they are up high, they push all the hot air at ceiling height out the door and cooler air replaced it from down low. seem to work pretty well. this squirrel cage type moves way more air then the vornado I used to use.
Charles (in GA)
50 mi south of Atlanta
Ceiling fans (if you have the height). Wall mounted industrial fans (like the pedestal fan shown above, just on a wall bracket), roll around drum fan from Home Depot, several cheap box fans from Wal-Mart either on the floor or hung from hooks on the wall and ceiling so they point down at an angle, take your pic.
Charles
DCarr
I have a 30" drum fan from HD. USA made and works great. I'm going to get a 2nd one to mount to the ceiling.
fred d
Metro Houston Area
I have 2
1 air mover shop vac and an old blower fan from a house air conditioner
I sit the blue one on the house fan
Steevo
43.49600, -112.04300
My shop fans are kept in line by my shop security team, and as long as they keep it orderly and stay behind the velvet rope, they can stay and watch.
:lol_hitti
DavesGarage
Phoenix, AZ
I bought the $200 pedestal fan from HD. Makes a lot of impressive noise but doesn't push much air even for as big as the fan is. I also have a Dayton 24" that has a motor going out on it but when it worked, it worked great! Will be replacing the motor soon, strange that Baldor was out of stock on the motors that would replace the Dayton motor.
TEXACMAN
Mount Pleasant Texas
I was given an old attic fan so I built a box around it and use it all the time in my shop , on deck during parties ,construction projects etc.... But with 100 degrees temps I installed a 5 ton a/c last year. :thumbup:
Jack Olsen
Los Angeles
I'd prefer tohave Steevo's setup, but I have an attic fan that I put up in my roof. It pulls the hot air out and moves enough of the stuff so that you can hear a sort of 'shuck' sound when I switch it on. It drops the temperature pretty quickly -- although it ain't the same as AC.
The downside was that I had to cut a hole in my 88-year-old roof.
It was only about $80 when I got it. It claims to move 1200 cfm.
T
The Frisco Kid
Central Texas
I got the industrial, wall-mounted fan from Northern Tool. I have the 20" and it really moves some air (3 speeds and it oscillates). Very pleased with it. All-metal casing. Relatively inexpensive, goes on sale this time of year...
And, of course, I customized it a bit...
View media item 22549
machin punk knocks it out of the park! I'm going to grab two of those 20" fans. Mount one at the back of the shop, and one more halfway. Should help to move some air in there!
pseudorealityx
USA
What are you doing for make up air? Cracking the garage door? I don't recall you having a man-door on your garage. Otherwise, you're sucking air out of your attached house, which isn't ideal.
Coloradotrailrider
Brighton Colorado
The home Depot industrial 60 inch fan moves a lot of air, works great. I also have the "L" shaped tandem garage. I mounted mine in the back tandem portion of the garage which is where I do most of my tinkering.
pseudorealityx
USA
The bearings aren't designed for a side load, so I believe you'll have problems there. Also, fans are terrible at 'sucking'. The velocity profile is tiny. They're much better at blowing.
I don't really understand the reasoning behind doing it. Care to explain more?
hippie2cams
Huffman,TX
my shop has a/c and heat now but it used to be fans, wall mounted on three walls two to a wall and wired w/a switch for each two fans so I wouldn't have to climb a ladder to shut them down or turn them on. Even with the a/c it takes no time to cool down in the hot summertime. :beer:
Fishplate
Athens, Georgia
I got a ceiling fan from FreeCycle. Does a good job easing the stale air, and the price was right.
Last month we removed a whole house fan from our attic and put stairs in. the contractor tossed the fan out by the dumpster. I recovered it, thinking I would put it in the garage (24'x26') but the thing is just so big, it might not be worth the trouble.
Randy in Maine
The Beach
I use 2 Vornado 293s mounted in 2 of my windows in MDF board so they are removable. Works pretty good and draws out 1400 CFM. They only use about 84 watts each and are pretty quiet.
James-W
Southeastern Wisconsin
Fans are fine up to a point, but once the temperature and the humidity get above a certain level, then you really need air-conditioning if you want to work in any kind of comfort. I have a fan in the corner and it blows a lot of air around. It works OK but once the temperature gets into the 90's and/or the humidity gets pretty high, the air-conditioning gets turned on. I enjoy working in my garage/workshop but extreme heat/humidity takes the enjoyment right out of it.
danski0224
Near Naperville, IL
You need an axial fan air mover.
These are common in the flood restoration industry. Very durable, low power consumption and lots of air movement.
This is one example: http://www.powr-flite.com/product/f6+downdraft+dryer+-+airmover.do?sortby=ourPicks&refType=1
I happened upon one at a local orange box tool rental center on sale at 50% off.
It beats the pants off a residential furnace squirrel cage fan and uses 1/4 the power.
jasonvt
Wesley Chapel, NC
I have an airking 20" whole house fan mounted in a window in my garage. When its on, Ill raise the garage door a couple inches. I have an app Friday to have a GF-14 garage fan installed. theyll install 2 vents in the garage door so I wont have to raise the door anymore. I have an unfinished storage area above my garage that the fan will vent to. Does anyone have one of these fans? Im hoping it will keep the storage area cool as well as the garage. Ill keep the window fan in since it can be set to intake or exhaust. Its right in front of my workout area so it helps the immediate area feel cooler when on intake.
